Question about Olympus Camedia C-830L Digital Camera
IS THERE A LEAD THAT WILL FIT INTO A MODERN LAPTOP. AS THE ORIGINAL LEAD HAS NINE PINS AND NEW COMPUTERS HAVE FIFETEEN
  • 77 Answers
Get a USB adapter, that is the easiest solution...
Posted on Feb 03, 2010
How do I get the photos from the phone to the 'puter?
you need a lead from phone to computer. the lead plugs into the same hole as the charger but has a usb fitting on the other end. most phones come with this lead supplied and are some times plugged into the 3 pin plug ( check to see if the lead from your charger unplugs from the plug end )
Apr 29, 2015 | Computers & Internet
Motherboard msi 7610 ver 2.1
To reset the motherboard: set the dipswitches at OC_SW1 to ON-OFF-ON, then clear the CMOS Ram by setting the jumper at JBAT1 to pins 2&3 while the power is OFF. Wait fifeteen seconds,Then return the jumper to pins 1&2 and turn the power on. This will re-set you to the factory defaults. You will need to enter the BIOS and re-configure your hard disk. The manual can be downloaded at ECS's website at: http://www.msi.com/product/mb/P41TC31.html#/?div=Manual
Apr 18, 2014 | MSI Ms-7610 P41t-c31 Motherboard Intel G41
Need to connect my J-NAV 500 GPS to my laptop, however, manual doesn't help much regarding which wires to to which pins on the 9 pin "D" connector. Thanks
This device if the manual is right uses an RS232 connection, what you are goiung to look for is a nine (9) pin connection it will look similar to your VGA connection on your computer. Do not connect the cable to your VGA connection, the nine pin connector will connect to the gps unit and the other end of the connector will connect or at least should connect to your computers com1 one connection or maybe the usb connection not sure. Should note that this unit has been dicontunued and the only manuals i could find were in Japanese which i don't speak, but that should be your connection.
Hope this helps
Jun 26, 2011 | JRC Plot 500F GPS Receiver
NO LEADS, CAN I USE MY LEADS THAT FITFROM OTHER PC/MONITOR?
Hi.
Yes, you can use the monitor leads from other monitors, just make sure that the pins are the same.
Some monitors have a 9 pin connector, and others have a 15 pin connection.
The jacks will look the same, but the 9 pin version will have the other pin holes filled in.
As a rule though, most modern monitor cables should work for you.
I hope this helps, and good luck.
Mar 14, 2011 | Hansol H550 15" LCD Monitor
My power suplly is broken and i cant use my xenyx1002fx. can i order a new one?how mach it cost?
Broken pins are common on these power supplies. The units are hard to find. If yours only has broken pins in the connector, find the connector type and have it replaced. Fifeteen minute job...
They probably use MINI DIN types available from Digikey.com or Mouser.com.
May 30, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Car misfires thoughout the whole range. new plugs & leads fitted. compression checks out ok
It's almost certainly got a failed engine sensor, but as modern engines are computer controlled robots which rely on sensors for all aspects of their operation you need to get the car plugged into a diagnostic tester to know which one is the problem.
Sorry, these are not like older traditional electro-mechanical engine feedback and control systems where there were distributors, HT leads, points, carburettors etc. They were all sources of inefficiency and unreliability but were usually easy to diagnose and fix.
Oct 15, 2009 | Ford Focus Cars & Trucks
I'm installing a card reader that has 5 wire connector tto the mb. The old card reader has a 7 wire connector that fits the mb. Its an Asus m2n68-vm. Thanks
These card readers normally fit the auxiliary USB socket on the motherboard. They usually take up all nine pins, four on one row and five on the other with a 10 socket plug. One pin missing on the end of a row.Such card readers have an additional external USB port as well as card reader slots. If it is just a straight five pin plug but with four wires it just fits over one side of the nine pin USB socket on the motherboard. The black wire goes at the end with the missing pin.
Mar 29, 2009 | ASUS P4P800SE Motherboard
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
Can i fit a new graphics card
Graphics chips on laptops are usually part of the motherboard and therefore cannot be changed.
Your only choice is to get a new and usually a better laptop.
Most desktop computers can accomodate new graphics cards by installing them in AGP or PCI slots, most modern graphics are AGP type cards.
Nov 14, 2008 | Computers & Internet
Location of 12v output and ground
u may ake 12 v output from battery lead.
basic need for inverter
1 power 2 ground 3 inverter on off 4 brightness
Oct 28, 2008 | Acer Aspire 5610-4648 Notebook
Olympus Camedia C-830L Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
