Question about HTC G1
Bluetooth in my G1 doesn't work-it can see other phones around but is unable to connect to them,it can only pair with them.Besides that I can't send or receive pic messages.What should I do?
    Brigadier General:
  • 3,006 Answers
Nothing. That's exactly how it's designed, both the G1 and G2 (a.k.a. HTC Hero) have a very crippled form of Bluetooth which cannot be used for file transfers of any kind.
It will pair up for Bluetooth headsets, but even then the chipset will not allow Bluetooth voice dialling.
As this is purely a hardware limitation there are no apps, firmware updates or updated OS releases which can fix it.
Sorry to disappoint you, but I hope that you've found my posting to be of some use. All I ask in return is that you take a moment to rate my answer.
Posted on Feb 03, 2010
Bluetooth paired but not coneected
How to pair and then connect to a Bluetooth device on your T-Mobile G1 Google smartphone.
1. First, ensure Bluetooth is enabled.
2. From the Home screen, press Menu.
3. Select Settings.
4. Select Wireless controls.
5. Select Bluetooth settings.
6. The G1 starts searching for Bluetooth devices in range. Select the device when it appears.
7. Type the PIN for the device.
8. The device should then pair with the G1. You can then select the device name to connect.
Bluetooth only supports ad2p profiles for headsets, music, and sharing of contacts and pictures. This is limited by VZ. Until the phone is rooted, there is absolutely no way around this. You cannot send files other than contacts and pictures via bluetooth.
It sucks... I know. I am in the same boat. I am [im]patiently waiting for the droid to be rooted so I can use bluetooth to share files between two droids.
Feb 24, 2012 | T-Mobile G1 Android HTC Google Smartphone...
BLUETOOTH
theres an app on the app market called androbex that lets you send files but not receive. just a suggestion as to receive files should become available soon
Aug 08, 2009 | HTC G1
Bluetooth problems!!!
you need to pair the devices in order to connect and use the bluetooth. Its for security reasons.
once the pairing is done you can use it
to pair go to bluetooth menu then options or configuration >devices>add new
now search everything will be fine
Jul 02, 2009 | HTC G1 Smartphone
Bluetooth not accepting anything
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
May 27, 2009 | HTC G1
Unable to pair Nokia N85 to Parrot car Kit
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
Mar 03, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Bluetooth My husband and I both have upgraded to G1 phones and neither phone will connect to bluetooth, we have tried with several phones, we can pair up to another phone (and each other) but when we try...
hiya, the G1 does not let you connect to other fones and will not enable you to send ringtones pictures etc wether it is a g1 or any other make! t-mobile are working on this to set up the application! they will notify us g1 users when it is available. hope this helps you out
all the best
kel
x
Jan 02, 2009 | HTC G1
Hi
I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
And now somewhere from net I found the solution to my problem.
Although it could not be done by bluetooth, but my problem is solved now.
You can also try it. It may help you out.
> Transfer ringtones/music/photos from your phone to Desktop
> Connect G1 to Desktop by USB cable
> On the top of G1 screen it will show the icon of USB (connected)
> Scroll down from the icon and select 'copy files from computer'
> Select 'Mount'
> On desktop a massage will appear, click 'open folder & show files'.
> Copy & Paste files from computer to G1. Now your files are in G1
> If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
Dec 01, 2008 | HTC G1
Bluetooth
you must enter thesame pin to the person who sends you bluetooth
Dec 24, 2007 | Samsung SGH-U600
Nokia N95 Bluetooth
Almost there gizmo1. In fact one has to go through Connect, Bluetooth then you'll see two tabs. The selected tab has the basic bluetooth options (On/Off, Visibility, name etc) and the second tab shows the list of paired devices. Access this by pressing right.
Once in the list of paired devices Press OPTIONS (normally the left softkey) then "New paired devices". You'll then see what's around and you'll be able to initiate the pairing.
If you're simply looking to send an object, you can do this from the file manager or media library. In the media library select your picture or other object then once again through the left softkey (Options) you should see a "Send" option. Select that, the Nokia will then propose how you wish to send. Choose bluetooth. In the file manager it works in the same way.
Sep 20, 2007 | Nokia N95 Cellular Phone
HTC G1 Logo
431 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
