Question about Toro Lawn Mower With Toro Power Tools
Replace right front wheel-self propelled walk behind mower
Right hand thread?
resists turning both directions
how to remove?
something special here?
Model 12AV565Q711
96342
Leaned on it
Posted on Feb 04, 2010
The self propel system slowly stopped working and now doesn't work at all, what could it be?
You didn't specify the make or model of your mower, but generically speaking for self-propelled walk-behind mowers, the drive belt or the front wheel gears can wear out after several years of use. The drive belt could also be loose or off the pulley. The belt and the front wheels can usually be replaced.
You can remove the drive pulley cover and see if the belt is off.
The other components that make up the drive system are the gearbox and the engagement cable. Sometimes the cable can get get out of adjustment or come loose.
Jul 23, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Husqvarna Model 5521BBC. variable speed, walk behind, self propelled. The mower start fine, goes into cutting gear, but when I try to use the "self-propel" feature, it does not engage. It's rear wheel...
yes it could sounds like the cable is out of adjustment remove cover to see if belt still mounted and how to engage selfpropepelld adjust cable accordanlly
Aug 23, 2013 | Husqvarna Garden
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a Toro walk behind self propeled mower. Last summer my sons hit something which made the mower stop running. I was told that I needed to replace somesort of key...? How...? How do I get the top off....
Was it the 'flywheel key' ? Does it yank the rope out of your hand violently when you try to start it?
Take the top shroud off, remove the flywheel nut, washer and screen. Remove the flywheel by threading the nut back onto the crank end to protect the threads and with a brass hammer ( and while lightly prying with a screwdriver from behind the flywheel) and a few good solid taps on the end of the crankshaft the flywheel should free up.
Remove the flywheel and inspect the key. Even .001th off will make the motor run funny or not at all.
Dec 07, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman self propelled walk behind lawn mower sef propel handle will not engage..the wheels will turn if you hold the handle down but the handle won't lock in........is something broken in the gear box?
Normally grass and debris are clogged under the belt/transmission cover, preventing the full engagement of the transmission cable/lever.
The cover is located on the topside, left front corner of the mower shell. Clean debris, try it again. If OK, re-install cover, If not, there is a cable adjustment (threaded portion with a nut on either side of a fastening arm) move the cable adjustment towards the rear, this will tighten the cable. Sometimes the cable assembly (includes the cable and the control box) needs to be replaced
Nov 08, 2009 | Craftsman Garden
Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Aug 16, 2009 | Garden
Need instructions how to install belt on self propelled craftsman push mower
raise the front of your mower up and support it with something safe like a jack stand
take the blade off
when your blade is off locate the plastic cover covering the belt and remove
now remove the belt but first remove the plastic cover on top of the mower to uncover the gearbox that turns the wheels your belt goes from the engine pulley to the gearbox pulley
you will have to work the belt off the pulley while turning the motor by hand or the same when installing the belt.
to install belt reverse the procedure.
hope this helps some
Jun 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Toro Lawn Mower With Toro Power Tools Logo
164 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
