Question about KitchenAid KSRS25IL Side by Side Refrigerator
My refer is at 41 degrees just had the difusser
My refer is at 41 and goes up to 55 and then back down to 41 degrees just had the difusser replaced in nov 09 just started hearing a clicking noise last weekend from the back of the refer? no more clicking right now , Its 8 years old
  • 52 Answers
Maybe your evaporator needs cleaning, I'd check that.
Posted on Feb 04, 2010
1991 Dodge Dakota this code number came up 12411155 what dose it mean
To read these you break them down into 2 digit numbers:
12 Direct battery input to PCM was disconnected
41 Generator field not switching properly
11.Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference detected during cranking.
55. END OF CODES.
12 is normal and 55 is the end of the sequence
Jan 16, 2016 | Dodge Cars & Trucks
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
Refrigerator temperature will not stay in 30 degree range for any period of time. It seems to repeatedly go up to 55 or 60 degrees and then drop back down to 38 degrees for a bit. In contrast, the freezer...
have you done a continuity test on the t-stat and the heater also when you did replace the fan did you assure that you defrosted the airport holes that go from the freezer to the fridge area lastly if the t-stat and the heater check out to be working properly then you might have a sensor problem but first check out the tstat this is usually the first thing that goes on fridgerators please remember to rank how this opinion helped in your appliance situation and if i can aswer anything futher please message me back thank you again
rickead1
Sep 02, 2010 | Samsung RS2630WW Side by Side Refrigerator
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET...
First to be sure shut the breaker off then turn back on. Most breakers require that you do this for safty reasons. Check all your power from the breaker to the back of the motor with a meter. If you have power shut it off then open the pump by removing the steel clamp that goes around the pump. Pull the motor and back half of the pump away from the rest of the pump. Now remove the difusser, the white plate covering the impeller. Then try to spin the impeller. If it spins then try to start thr motor. If it goes then you have a problem with the impellor or the difusser. If it won't start at this point you probally have a bad motor and will need to replace it. I always recomend new but you can get a rebuildt. If it's the impeller that will usually be obvious. You can take it into your local store and have them match the parts and they will usually do the bench work for just the charge for parts.
I hope this helps, good luck.
Aug 31, 2010 | Sta Rite Sta - Rite 2hp Max - E Pro...
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Sep 10, 2009 | Westinghouse Refrigerators
Changed a/c evaperator and compressor, runs about 48 degrees temp goes up when you slow down cant find screen in high side line.
Is your cooling fan working properly? Usually when going down the road, it will cool better due to more airflow over the condensor. If your cooling fans are not working properly, this will add to the effect. Is it going to like 60-65 degrees at idle, or like 55 degrees? 60-65 is cooling fans, 55 most likely normal. Would have to see what your gauges are reading to let you know for sure. The orifice tube you are looking for is in the high side A/C line near the evap core. Look for a place where the line can be undone, with dimpling to hold the tube in place.
Jun 09, 2009 | 1998 Chevrolet Cavalier
The codes for stareview cw wont work
try these
00= 95 db 55 38 8d a0 5c 96
01=d4 82 b9 87 8b 37 43 b7
Dec 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
Air difusser between freezer and fridge will not stop running
When things like this happen I usually replace the main electronic circuit board which would control the motor operation timing, etc.
Nov 29, 2008 | Whirlpool Refrigerators
Kitchenaid KSRA22ILSS02 fridge won't get below 41 degrees
Try shut down for overnight and turn back on next day. I had same problem - cooling air duct was blocked by ice
Oct 08, 2008 | KitchenAid KSRA22ILSS Side by Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
