Question about Cell Phones
Blue tooth won't stay connected with phone
My Everwin slx800 bluetooth won't stay connected with my cell phone. It works for a couple of weeks then won't. I've taken into the AT&T dealer three times. They fixed it twice, then said they could solve the problem the last time.
Also, I can't find the instruction manual on the blue tooth.
Any help will be appreciated.
sharon_daley@comcast.net
SOURCE: Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Posted on Jan 03, 2008
SOURCE: LG CU500 cell phone Call Divert Set problem
  • The issue is caused by the phonejack/memory chip assembly, located in the upper right rear of the phone has become unseated/loose and is causing your issues. I had the same problem and after I took the phone apart and put the assembly back in position, I eliminated the problem.
  • If you are not mechanically inclined and/or have access to small tools and an open area to work in, do not attempt!!!! There are numerous small parts including the side buttons and keypad and the above mentioned assembly that are exposed when you seperate the two sections that make up the back of the phone. If you attempt the repair be extremely careful to note the position of parts before you take it apart and make sure they go back in correctly. It is a bit time consuming but doable.
  • If you feel you can't do it yourself I'm sure that there are some online options for repair or perhaps a local repair shop that would do the repair. Good Luck
Posted on Jan 05, 2008
SOURCE: samsung U 600 failing to connect to blue tooth conection
i have purchase a phone with a bluetooth that comes with it. the bluetooth would only light up while it is charging and blue when it is ready. but it will not turn on at all. please help me solve this problem or give me info of where to call. thanks. lucy
Posted on Mar 22, 2008
IrishDruid
  • 2712 Answers
SOURCE: need instructions to set up blue tooth in my phone
Yes, it would help if you gave the model number. However, if you do a google search for LG Rumor user manual, you should be able to find a download.
Posted on Jun 16, 2008
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Posted on Jul 04, 2008
My Bluetooth and speaker connect but it wont stay on after one or two songs it keeps shuting down kicking my Bluetooth off on my phone
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Hasn't cut out since pairing it again !
Feb 03, 2017 | Cell Phones
When I turn my iPhone Bluetooth on it won't find the Craig blue tooth speaker!
Any Bluetooth device MUST be discoverable for the phone to find it.
Does your Craig have any setup program / configuration where you can set it to be 'discoverable' ?
Feb 17, 2013 | Cell Phones
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
How do I connect hands free blue tooth to an LG incite
hold the on button on your bluetooth headset until it blink and stay lighted then turn you cellphone bluetooth on and click search for bluetooth device. your bluetooth headset should appear then click connect
Jun 08, 2009 | LG Incite Cell Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Bluetooth Problem
insde the phone setup for the bluetooth there is a mute function some phone have a mute button located on the edge so they can talk privately to someone else while holding a conversation about a problem etc also the headset has a mute button check that this has not been set in some way
Feb 16, 2008 | LG Shine KE970 Cellular Phone
Cell Phones Logo
117 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
