Question about Dryers
Dryer won't start when button is pushed. The
Dryer won't start when button is pushed. The inside light goes on when door opens so power is there. Drum does move, had belts & rollers replaced 6 months ago. could it be the fuse?
  • Dryers Master
  • 8,220 Answers
This is a broken belt symptom. On some models when the belt breaks the idler drops down and hits a micro switch that kills power to the run windings. So that the motor won't run and cause the heater to come on. This is a safety feature. Post your model number for a more precise answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Feb 03, 2010
The Dryer won't start. Power light just flashes red on and off
There are too many problems that it could be, anything from the Button going bad, to the Door Shut Switch being defective, to the Motor, Relay inside the circuit board, to loose wire during the move, and the list goes on and on. Unless you can test each component that sends the START signal, nobody will be able to assist you with the information you have provided.
Mar 01, 2014 | Hotpoint Ariston AWD129 Front Load...
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
When I push the start button nothing happens; no "resistance" from the button, no clicking sound. Power is on as light inside dryer goes on.
Hi- Sounds like you just need a start switch but possibly a door switch (the dryer won't come on if it thinks the door is open). Depending on what model you have the start switches usually aren't too expensive and easy to replace. Just be SURE that the dryer is unplugged anytime you work on it. Hope this helps...
Sep 24, 2010 | Dryers
Just stopped working still has power-inside light comes on and timer makes noise when you turn dial but does not start when you push start button
This sounds like the door switch. But it could also be the non-resettable thermal fuse inside. Open the door, depress the door switch until it clicks, and while holding it in see if the dryer starts.
Jan 05, 2010 | Whirlpool Dryers
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont start
Push on the door switch and make sure the light goes out. When the light goes out, a contact should be made to allow the motor to run. If you can get to the timer, spray a good electronic contact cleaner inside while rotating the dial. While you have the unit open, vacuum out all the lint, and check for loose wires, especially to the door switch.
Apr 14, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Oct 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
