Question about E-Machines W3052 PC Desktop
Computer shuts down.
My computer shuts down about 3-5 times then reboots itself. I was told to blow out the dust, which I did. I was told that it could be my power supply. If it is my power supply, what do I do? Do I go out and buy another power supply? The computer does not shut down if I leave it on for a whole day. But it shuts down when it is being used. Can you help me. This problem I have had for a while now. Thanking you in advance.
  • bong14 Jan 24, 2009
    Hello everyone.
    I have a problem also regard with this matter. My computer getting restarted when its running in a matter of time. This problem started when i change my i.p address in a wrong way. But when i correct it and type the correct information about my i.p address it getting worse. It destroyed and corrupt even my system applications and other software installed because it restart most of a time.
    I've formatted (3x) already my hard drive and re-partition; remove my system clock to reset my bios. But when i run my computer, the problem is they same it restarted as there is no change happened.( Windows message is that there is a conflict in hardware and the Operating System with i.p. address.)
    Please help...
I have the same problem. my computer keeps on shutting down every 4 to 5 seconds. by the time i finish this sentence, i am pretty sure it will shut down and i will have o start all over again. it's pretty annoying...
Posted on Dec 04, 2008
I have the same problem. my computer keeps on shutting down every 4 to 5 seconds. by the time i finish this sentence, i am pretty sure it will shut down and i will have o start all over again. it's pretty annoying...i thought i had a virus, but i have installed norton anti-virus and it has not resolved the problem. i am fed up.
Posted on Jun 17, 2008
  • 22 Answers
Hello when was the last time you cleaned out all the dust inside? there may be lots of dust on your processors heatsink and it is getting to hot obviously it will get hotter when you are using you pc and may shut down your pc otherwise get a new PSU (power supply unit ) they are quite cheap have a look on ebuyer.com or ebay
ps, you could get some new paste on your processor so the heat is transfered better to your heatsink.
djdizzys
Posted on Feb 20, 2008
    Genius:
  • 1,226 Answers
Hello;
So i guess that the PSU is good. As i diagnose of what you have said, i digested a conclusion that when the computer shutdown when application run. there a problem conflicting the application to another application or such an application trigering the system to shutdown.
Some causes of this problem are:
The system is infected by known and unknown virus
The driver of the system are not properly installed
The application program committed an errors trigering the system to shutdown.
Possible solutions:
1. Scan you system with a potent anti virus
2. Remove the installed driver of the sytem and reinstall it after restarting
3. Unistall the application that causes shutdown problem and you can reinstall it after restarting.
4. remove newly installed hardware or install the correct driver of the hardware.
Note in scanning your system with antivirus you should scan it it safemode.
some usefull links: http://www.precisesecurity.com/antivirus/online-scan.htm
If all the solution did not work to your system. please notify me for further solution.
best regards, melnavz
Computer shuts down unexpectedly
A computer that is shutting down as opposed to rebooting usually indicates a heat problem. The computer will shut itself down to prevent damage. If it will run long enough for you to log in and use it for a bit. You can download and run speedfan. It will give the temperatures from your computers sensors. Usually the only one we care about will be the CPU. If it's getting up around 75 C then you certainly have a heat issue. You will want to go to radio shack and get some "thermal compound" the best one is Arctic Silver 5. It's about $10.
Service Manual for your laptop
Once your at the heat sink remove it and either on the heat sink or on the cpu itself where you see some grey compound. If there isn't much there put about half a pinky nails worth of the paste on it in the center. It will heat up and spread out on its own.
Also if there is a lot of dust, use some canned air to blow it all out.
Dec 30, 2012 | Acer Aspire 5742Z-4200 Notebook
For a week now my laptop has been overheating,then will shut itself down,the overheating happens rapidly,all internet connections have slowed exponentiallyy as a result,is it fan related?the laptop is
The laptop will need to be dismantled down to the motherboard level, use a can of compressed air attach straw and blow out all ports, heatsink and fan. It might be a good idea to remove both for closer inspection and several good blast of air for good measure, and check the thermal paste between the heatsink and processor ic has not dried out.
Apr 09, 2012 | Compaq Presario CQ62-112TU
LAPTOP JUST SHUTS OFF AFTER VARIOUS PERIODS OF TIME. NO WARNING AT ALL. DOESN'T SEE LIKE A BATTERY BEING LOW AS THERE IS NO WARNING AND UNIT PLUGGED IN TO AC
It probably is overheating, and is shutting itself down, to avoid PERMANENT damage.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give the computer a "blow-job" -- shooting compressed air everywhere into the vents, to remove a layer of dust, that has been acting as insulation, causing your computer to overheat.
Dec 11, 2010 | Computers & Internet
Acer Aspire t690 Desktop Freezes or reboots with in minutes of start up...Running Windows Vista. Help???
It is possible that your computer is overheating and is shutting down to prevent it from doing any harm to itself.
Make sure that all fans are clean, there must be no dust present as it hinders airflow!!!
Install as many fans as possible. Computer temps should be in the region of 30-40 degrees centigrade. To avoid CPU throttling, where the CPU slows down to prevent frying itself.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Computer heats up and shuts down
I would suggest you open the notebook by yourself and clean it from dust. I had an Acer notebook that shut down very often because it had so much dust inside that it overheated.
Jul 23, 2010 | Acer Computers & Internet
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
Computer automatically powers down with out warning
It could be overheating, and shutting itself down, to avoid heat-related damage.
Disconnect the AC adapter.
Remove the battery.
Purchase a can of compressed air, and give your computer a "blow-job" -- shooting compressed air everywhere "inside" your laptop, to remove dust.
The dust is acting as an insulator, preventing your computer's fans from cooling itself.
Or, take your laptop to a qualified computer technician, for more trouble-shooting.
Jan 24, 2010 | Gateway M-1628 Notebook
PC keeps shutting down and then re-boots automatically about every 20 minutes .
Shut it down.
Remove the power-cord.
Buy a can of compressed air ($3 to $5).
Remove the side panel(s).
Hold the can of air vertically (do not tilt it),
and blow away the dust from everywhere: inside the power-supply,
between the "blades" on the heat-sink & fan on top of the CPU.
Replace the side panels.
Reconnect the power.
Start it up.
Click Start
Right-mouse click on My Computer
Choose Properties
Choose Advanced.
Under "Startup and Recovery", click "Settings".
Click to disable "Reboot Automatically".
The next time that it crashes, what error-messages _stay_ on the screen?
Oct 10, 2009 | Microsoft Windows XP Professional for PC
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Philips pc camera SIC4750/27
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Oct 02, 2007 | Philips J44414
E-Machines W3052 PC Desktop Logo
113 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
