Question about Dell Latitude D510 Notebook
Dell Inspiron8600 laptop - StartUpProblem=UNMOUNTABLE_BOOT_VOLUME
Dell Inspiron 8600 laptop --- StartUp Problem = Blue Screen = UNMOUNTABLE_BOOT_VOLUME (even in SafeMode) "STOP: 0x000000ED, statusCode=0xC0000006 (means WHAT????)" ...MSDN's'BugCheck' says the StatusCode="The status code from the file system that describes why it failed to mount the volume" ..but no other 'hints'
****how do i find out what it means??? ****
//**also, BlueScreen suggested "disabling BIOS memory options such as caching or shadowing"
...but can't find and way to do that via F12(BootMenu) or F2(SetUp) ***do you know how???***
// Tried: (at beginning of startUp) => F12 (BootMenu) // selected 'Diagnostics' // 'Pre-boot System Assessment' ______= Failed //
"Booting Dell Diagnostic Utility Partition-pressAnyKeyToContinue" // ...=>HardwareDiagnosticProgram // selected "SymptomTree" + "HardDriveErrors" ...=>DeviceSelfTest, result="ErrorCode: 0F00:013E, Msg: "IDE device failed: A possible failure is predicted by the drive's S.M.A.R.T. status. It is advisable to immediately back up! "the given erroe code and message can be used by Dell Technical Support to help diagnose the problem. - do you want to continue testing? // selected No + manually selected "ConfidenceTest" , result= "ErrorCode: 0F00:133E , Msg: (...same as SelfTest resultMsg)
***....looks like the hardDrive (HD) is 'toast'!!???*** ....where do i go from here???*** ...is there some 'magic' way of resurecting the HD???*** ....if not, is there any way of recovering (any?) of the files so they can be moved to a new HD???*** [no backUp position available!!]
Thanks for any light you can shed on this mess...
longggene
  • 4,889 Answers
Device failed to mount usually points to a harddisk crash. Take it apart and check if the device Cable(IDE/SATA cable is loose) or the power cable of the hard drive. Just pull it an plug it back in and see if it resolves the issue.
You can recover your data but as always it has a price. However you can check if the data is salvageable using the demo version of the software and scan the drive for any recoverable data before you consider buying it. Download the demo from the link below burn the ISO image to a CD or DVD and boot from the CD and run a scan.
http://www.prosofteng.com/products/data_rescue_pc.php
It will report results in a very detailed manner. Files marked good or excellent are recoverable. Anything below that(average, bad, poor) are usually un-salvageable by a typical home user. It requires proffessional data recovery tools.
Other wise you can simply format the drive and re-install the OS.
Let me know if you have any more questions,
Sai.
Posted on Feb 03, 2010
3 Suggested Answers
SOURCE: Dell Inspiron 8600 laptop - StartUpProblem=UNMOUNTABLE_BOOT_VOLUM
OK simply your hard drive has failed... You need to get a new one, and install it, in the laptop after taking the old one out. Then you will have to install an Operating System. & Drivers all again. You could download all of that from the Net.
  • 157 Answers
SOURCE: Dell Inspiron 8600 laptop: StartUpProblem=UNMOUNTABLE_BOOT_VOLUME
If the hard drive is toast, you are out of luck. Seagate offers recovery services for bad hard drives, but there are no guarantees on a failed drive. Have you tried repairing the windows o/s. If you use the original Windows Release disc, it will examine the disc drive and find the current operating system, based on your input, it will attempt to repair the O/S without you loosing your data. YOU MUST BE CAREFUL TO SELECT THE CORRECT OPTIONS.
If the windows O/S CD has problems with your hard drive, then the next step would be to talk to seagate.
I have a blue screen that says "UNMOUNTABLE BOOT VOLUME" And system will not boot up any further?
This means that the hard disk drive has a problem. It could be an electronics failure or it could be a driver problem. Try to start the computer in SAFE mode by pressing the F8 at bootup. This will verify the hardware.
Jul 14, 2014 | Dell Inspiron B130 Notebook
Unmountable boot volumn error with lines on screen
this may help. just watch the video and folow the directions. good luck.
Apr 11, 2013 | Dell Inspiron 8600 Notebook
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1300 will not go into safe mode. I am getting a blue screen with a message Stop (oX00000000ED) (oX82F99868) (oXc0000006) (ox000000) Unmountable - Boot - Volume. I have no idea what...
Best case is your os files corrupted, in that case you can try reinstalling your OS. If that does not work then there may be some hardware issue, it'll best if take it to support center.
Mar 14, 2011 | Dell Inspiron 1300 Notebook
No complete starting
Unmountable boot volume means your harddrive has gone out.You will have to get a new one and load your os again.Sorry:-(
Apr 08, 2010 | HP Compaq Presario C502US Notebook
Feb 03, 2010 | Dell Latitude D510 Notebook
Dell Inspiron8600 display is blank. It begins booting, the screen flashes with the Dell logo then it goes blank. I can see faint images on screen but can't read anything. Can I hook up to an external...
If you get the boot image on your screen then you screen is working correctly unless there's something that you not explaining. You can try an ext. monitor if you think it is something related to your LCD screen not woring during boot up. If the ext monitor not showing your laptop to boot then you have problem with your OS and may need to get it repaired or restored.
Oct 31, 2009 | Dell Inspiron 8600 Notebook
Blue screen unmountable boot volume error, I have tried to reboot with the CD windows XP and the F-12 and F-2 no success. I have tried to reboot in safe mode last configuration still no success.
Sounds like a bad hard drive. You can try using a live linux cd like Knoppix or Ubuntu
Ubuntu is easier for most.
That way you'll know whether it's the hard drive or another issue with the laptop.
Feb 21, 2009 | Dell Inspiron 1300 Notebook
Dell Latitude D510 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
