Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Superba oven removal
I am moving and will take the Kitchenaid superba with me. How should i remove the side trims to acces the screws that hold it into the cabinet?
Model KEMC378KBL01
SER XR1203953
  • 49 Answers
Im not familiar with this particular model but on most ovens you shoud only have to open the doors and the screws that hold it in should be visible. generaly 2 on each side
Posted on Feb 20, 2008
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
Have a microwave oven Litchenaid model # KEMC307. The light bulb doesn't go on anymore and we would like to replace it. I assume it is a halogen with 2 prongs that pulls out but it is very hard to get a...
Ok, pull the oven out, remove the 2 screws on side trim of oven, remove the screws from trim under oven, now above the oven, remove the other 2 screws behind the grill. This should give you enough room to pull the unit forward. The bulb is on top. Hope this helps.
Jan 04, 2011 | KitchenAid KEMC307 Electric Double Oven
The handle has fallen off my stainless steel kitchenaid superba oven and screws go from inside edge toward front. Can't tell how to access without removing frame and that's another question!
Yes the door has to be disassembled to repair the handle. In some cases you can just loosen the sides and top and work with it on your lap without removing from the unit but it takes patience and an extra set of hands is nice to have around. Any visible screws have to come out first. Eric
Aug 18, 2010 | KitchenAid Architect Series KEBC107KSS...
Is there a recall for this oven? Won't heat after cleaning
no recall, it sounds like you blew out the high limit thermostat, this is common on ka ovens the temp of the self clean cycle near 900 degress blows their thermostats, its a safety device it blows when unit gets to hot, usually range between 30-80 dollars, you could call for service or u could repair. if so remove to trim pieces usually two screws on trim from inside, then remove screws that hold unit in cabinet, i suggest getting two people then remove oven out or set on sometin to support it, oh yea turn off power to unit at breaker before servicing, then remove back panel to unit usually screws all the way around on back panel. then locate the thermosat on back, u can test it with a meter for continuity if it reads anything its good if nothing then replace the part....
hope this helps let me know how i did thanks
Feb 19, 2010 | KitchenAid KEBC107 Electric Single Oven
Can you explain how to replace the light bulb in my amana oven?the model number AARG7303WW
This worked like a charm ... actually it's easier than you might think. Just a few screws and a few tugs. Give it a shot.. I found a 10W (G4 style ... you'll see the difference when you get to the store) replacement bulb at Home Depot for $6:
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with your fingers or pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
Feb 14, 2010 | KitchenAid KEMC378KSS Electric Double Oven
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
How do i change light bulb for my oven
Here is a simpler method from the same website mentioned in solution #1:
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
By the way, the bulb is Osram 64405S. It's available online for about $2.00 plus shipping.
See more info. at: http://www.howtomendit.com/answers.php?id=51232
Mar 13, 2008 | KitchenAid KEMC378KSS Electric Double Oven
Microwave oven light - KEMC 307
you ll need to pull unit out to replace bulb, 2 scrws remove side trim of oven, 3 or 4 screws remove trim under micro; above oven, 2 more screws behind that grill will release micro from supportthat should free it up enoug to slide foward 6 or 8 inches( the bulb is ontop of the cavity) good luck!
Feb 25, 2008 | KitchenAid KEMC307 Electric Double Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
495 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
