Question about Bose Cinemate Digital Home Theater System Speaker
Bose surrond sound not working...
Tv sound is coming from the bose speakers; with the tv speakers down, the Bose systems does not work, even after I try turning up the Bose? are the wires connection wrong? I suppose I am missing something.
    Brigadier General:
  • 8,546 Answers
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Posted on Feb 03, 2010
I have lost my sound from TV through the Bose Lifestyle 48 recently. All other sound sources work fine- DVD/CD, FM/AM.
Hello Sunny,
No TV model... came through with your
Bose LifeStyle home theater question...
I'm just going to mention that I have seen a couple of available configurations... depending on your signal source... BROADCAST, CABLE, SATELITE... (etc.)...
If it is Just your intention to source from the TV...
THERE (at the TV)...
It might be as simple as going into "menu" ... then move down to your "AUDIO" PROFILE.. and make sure your external speaker OPTION is showing "ON" (or "equipped")...
on your TV and making sure your PRIMARY volumes sources & destinations (Bose) volumes at acceptable levels... so as to not FRIGHTEN your neighborhood when the sound does come through)
No success ... comment me back with your TV signal source...
HMDI or optical outputs... (and does your AUDIO Work in STAND-ALONE on the TV... Now??)
If all else is working on the BOSE... I don't think we need to continue there...
Comment me back if you need... I'll be around!
Post comments... addendum
(I did say Menu... (twice))...
RESET , General:
**WARNING:
This operation will clear all of your customized settings.
V... depicts the volume down button on your remote
(immediately above the "menu" button).
With the set turned off...Stand in front of TV.
At the right side on the TV set... locate the power
button on the right side...
WHILE holding down the V (on the remote)
Turn on the TV POWER button on the TV.
(The TV will turn itself off, then back on again.)
Then ... V (symbol) Release the button.
**WARNING:
This operation will clear all of your customized settings...
I'll still be here... comment me back... if you need.
Hope it helps
ELSE ...
We need to move on to your PCBs
Jul 21, 2016 | Bose Lifestyle 48 System
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
Bose 123 system and Samsung LED TV problem.....
yes use the Av cables for this connection . at the back of the TV there should be video in and Audio in connection.
for video its usually the yellow pin so yellow will go with yellow tv & m system
just follow colour code
ansd now u will get visual on the screen .
good luck dude
Sep 08, 2009 | Bose Cinemate Digital Home Theater System...
Bose cinemate no sound
Yes it will work coming straight off the dirctv box. What kind of tv do u have that doesnt have an audio out. I have had to actually use rca splitters to get sound from bluray and cable box because the new samsung led tvs only have optical out. Dont forget the unit not being used must be off or u will have 2 source sounds at one time playing.
Jul 03, 2009 | Bose Cinemate Digital Home Theater System...
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
No sound through Bravia speakers after BOSE removed.
Did you ever have audio through your tv before?
It's likely that your Comcast cable box was connected directly to your Bose system, and not your television.
You'll need to check the connections from your cable box, to your television.
Mar 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
Bose cine mate speakers
No it won't be like surround sound, but you'll have the next best thing: a nice, powerful, natural Hi-Fi sound. I have a 46 inch 1080p Sony connected to a Sony Blu-Ray and Bose Cinemate Speakers. No complicated rear speakers wiring, no awkward center speaker to hide. The only drawback is that Bose doesn't have (yet) a code to operate the Blu-ray player with the Cinemate remote control.
Hope this helps to make your decision.
Feb 17, 2008 | Bose Cinemate Digital Home Theater System...
Bose Cinemate Digital Home Theater System Speaker Logo
504 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
