Question about Kenmore Washing Machines
My kenmore washimg machine model 110. 25652400 cycle knob won't engage and start when pulled out.
  • 87 Answers
SOURCE: Kenmore 70 Series Washer
You probably have a bad lid switch.
Posted on Jun 08, 2007
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Posted on Aug 19, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
canbruce75
  • 1776 Answers
SOURCE: Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Posted on Jul 24, 2009
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
Washer Doesn't Start
once again check your lid switch where the lid hits when you put the lid down
Jan 15, 2013 | Kenmore 98702 Stacked Washer/Dryer
Washimg machine agitates and drains but does not spin
Mine had same issue. My problem was with the switch. Try gently wiggling the knob, then move it to the end of a rinse cycle, just before the spin cycle. Pull the knob out, and the timer should start clicking, after a few seconds you will hear a clunk sound as the transmission engages then starts spinning. I disassembled the unit and removed the motor, only to discover the coupler was not damaged.
Oct 27, 2012 | Kenmore Washing Machines
The cycle knob on my Kenmore 70s series washing machine is broken. I cannot turn it to pick an appropriate cycle. It just spins around without moving the "dot" to a new cycle. The push/pull...
You can replace the switches very easily, and you can order the parts you need from Sears on line. BUT you need to know the full model number of your unit to do it.
Find the part on the diagram that you need to replace and then look it up on the chart to find out what it costs.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11082873100/0582/0153200/00041757/00002?blt=06&prst=0&shdMod=11082873100
Jun 09, 2011 | Washing Machines
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 model 110
If you are talking about the Cycle Selection knob, turn the washer to an OFF position, or unplug. I can't remember if you need to pull the knob out or leave pushed in, but the knob will come off by turning it counter-clockwise. After unscrewing it and removing, the plastic dial under the center knob will simply pull off. I hope this helps you. If you need further assistance, please let me know.
Jan 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
313 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
