Question about HP DeskJet 5650 InkJet Printer
Door open !
"Door open! Close catriges access door " though the door is closed.
    Master:
  • HP Master
  • 406 Answers
Check the door switch under the cover: if bent straighten it, if broken amend.
Posted on Feb 03, 2010
  • JimWP Dec 11, 2010
    I had the same "Door Open!" (won't print) symptom with my HP5650 printer. The door (printer lid) would not close all the way. I found that if I tapped or pushed lightly on the far right side of the lid, just about two inches forward of the right side hinge, the lid will snap into the fully seated 'door closed' position. If you look under the lid about this same position you will see the plastic triangle shaped 'tab that presses on the 'door closed' sensor lever.
    In this model, the door switch cannot be bent (as suggested above) as it is only a plastic lever that interrupts a slotted optical photo detector on the other side of its pivot point. I hope this tip helps someone...
  • Maggie
    Maggie Jun 18, 2014
    Thank you JimWP! Your tip helped me and I signed up here just to say thank you!
Error code 3806
From Kodak support:
Open the printer access door.
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer.
Turn the printer on if necessary.
After the printer has powered up, the message "Printer access door open" will appear.
Close the printer access door.
Remove and install the printhead two times.
Wait until the printer is ready to use.
Jun 07, 2012 | Kodak   ESP5250 Es Printer
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
Won't print, orange triangle with exclamation point
This triangle light blinking indicates that a door is open. Open the front access door completely. Close the front access door completely. Open the rear door and close it.
If this didn't fix it refer to this guide for all errors you get with this printer from HP website.
Dec 16, 2010 | HP LaserJet CP1215 Color Printer
Door starts to open/close only travels 8" then reverses/stops
The problem is most likely with the safety "eyes" sensors. Your system does not see them. Rather than opening even without sensing the safety "eyes" sensors like most older system do, this model apparently has a safety feature built in, that without proper communication between the safety "eyes" sensors and the main console, the door will not operate at all. Some people had reported that in a situations like yours, if they the button on the remote pressed, the door will open/close, though this is not recommended.
Sep 06, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
All in one hp printer says "cover is open"? what do I do?
Dear Sir,
Step 1: Close door If the cartridge access door is open, close it. Figure 2: Close doorc00112062.jpg Then restart printer and try. Thanks For Your Time,
Apr 07, 2010 | HP Photosmart C6280 Printer
Access door open
Kindly close the access door then.If you are getting the message even after closing the access door,its time to call kodak at 1800 421 6699 and the printer will be replaced free of cost for you.Access door is the door that is opened to change the cartridges.
Sep 25, 2009 | Kodak ESP 5 Printer
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Access printer door ,got it open, but can not close it
you just need to apply the press on the front so it you will not bang hard. its hard to close you just need to apply a bit pressure enough not to break it..
Apr 08, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP DeskJet 5650 InkJet Printer Logo
558 people viewed this question
Seeker5211
Seeker5211
