Thermostat How to replace the thermostat on Frigidaire R5303B
Air conditioner wont reset
Posted on Feb 23, 2008
Where is the thermostat on a frigidaire refrigerator
Hello Friend, this is Z. Thank you for allowing me to assist you!
It appears that your Frigidaire refrigerator (GLRS2372AW7) has a manual thermostat. The sensing bulb for the fresh food thermostat will wrap around the front of the damper housing. The sensing bulb for the freezer thermostat will pass below the damper housing and extend into the freezer compartment. I hope this information helps to some degree.
Jul 21, 2014 | Frigidaire Refrigerators
My frigidaire freezer keeps turning off, I have to keep turning the temp control to turn it back on.
Sounds like you have a control issue. specifically a thermostat issue. I'd replace the thermostat.
Aug 14, 2013 | Frigidaire 20.6 cu. ft. Top Freezer...
Install a replacement thermostat in a Frigidaire range model #FEF352BAWB
This is not a typical DIY job so I would really consider contacting a professional technician to complete this for you.
Aug 24, 2012 | Frigidaire Kitchen Ranges
Frigidaire dryer too hot
check for air flow on back of dyer, also check the heating element. could be a bad heating thermostat in dryer. good-day !
Feb 10, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
Running to much and freezer to cold. Thermostat was just changed
This is under warranty. Just call Sears back and they will come out and fix it for free.
Apr 20, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Sep 13, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Compressor problems
it varies with door oppenings stuff like that sounds like you may have a faulty cold control the cold control has two settings a cut on setting and a cut out setting you cut in setting may be bad id replace the cold control
Mar 15, 2008 | Refrigerators
Heating & Cooling Logo
304 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
