Home | Coffee Grinders | Barista Coffee Grinder
Coffee Grinders
Problem for Coffee Grinders
Generic problem for all Coffee Grinders
By MarilynBr on Feb 19, 2008
I inadvertently turned the knob counter-clockwise and froze the machine...what.can I do to un-freeze it, if anything?
Thank you.....M.B.
Same Problem
Jan 28, 2009
-   baratza burr grinder went half way through grinding then stopped--heard a buzzing noise and pulled plug-
what to do -   jpect
Apr 13, 2008
-   We can't get the whitish part that surrounds the burr grinder out! We took it out to clean it, put it away and now when I want another cup and need to grind, the whole center section doesn't move! I admit I did try to put on the bean holder and it wouldn't fit so didn't force it but to see if the burr rotated I lightly stuck a small screwdriver down to see where the switch was to turn on the burr grinder and it does work. So, the only thing we have trouble with is the round whitish par that should just come out so it can be cleaned. It looks like it has to be rotated so the tabs can be released and then you can lift it straight up. Please help! Cheryl-   burrlyawake
Best Solution
posted on Mar 14, 2008
Very Helpful)
flyonwall
Rank: Wiz
Rating: 83%, 55 votes
Turn the knob back the other way, while the grinder is not running! This should free the burrs, if necessary then, dismantle, clean and replace.
If, when the upper burr is unlocked from the lower, the motor will still not run, you have done worse damage.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Mar 23, 2009
Not Rated)
steves123
Rank: Apprentice
Rating: 0%, 0 votes
i had this, You have to dismantle and remove the grinding mechanism. It is probably jammed up with coffee, i used a very small knife to work round the edges till the mechanism was free and i could take it out.
I found the actual cause of the issue was not cleaning the coffee grinder properly, a bean had been left on the dispenser hole. Its really hard to see when this happens.
If the coffee grinders refuses to work after, ehter you have blown the fuse ( the 1amp one actually inside the machine, under the base plate) or you have a blown motor.
Was this helpful?
Yes
No
Popular Solutions for Coffee Grinders
Questions and Unsolved Problems for Coffee Grinders
Answer
Grinder grinds but when I try to dose it won't turn inside to dose.
Answer
The grind does not change although I turn the grind ring. It is always teh same grind.Thanks
Answer
Hello. I am looking for a resevoir that the coffee grinds go into for a Briel CG-5
Answer
Avanti stove top coffee maker 6 cup. Need to replace seal in lid. Can I buy separately
Answer
it doesn't always grind the coffee-it just seems to stop and spin
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee Grinders:
Top Coffee Grinder Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee Grinder Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
