Question about Whirlpool Duet GHW9150P Front Load Washer
Trying to separate pump from housing but can't get it to turn far enough to clear the twist lock. is there something else to do before I can get it off?
  • 767 Answers
The pump and the motor are all one unit on this machine. If you have removed all the bolts holding the pump in and the hoses the pump and motor should be all in one piece.
Posted on Feb 03, 2010
I have a fisher and paykel top loader 10 kg but not spinning and make that humming noise when it's on spin cycle, water drains slowly.....please help
sounds like theirs a large blockage in the drain pump housing, the drain pump is just twist locked onto the bottom so you just lift the little white lock clip then twist the pump and it will come off and you will be able to see inside the housing and clear the blockage
Jan 28, 2017 | Fisher and Paykel Washing Machines
The T-turn is reversed
I my mind the actual lock bolt was assembled wrong. You need to gently twist the length adjusting unit /bolt directly out of its housing and then gentle separate the two pieces though fully separating them and then "flip" the actual little toggling metal piece that has the "U shaped and half circle looking hub that the lock shaft slides into, around from it currently position ... ie. reversing its throw. You may need to also adjust the spring metal piece underneath it as it run in a slot as well.
This worked for me ... when t-turn key is horizontal the dead bolt is extended ie. in locked position.
Apr 27, 2013 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Cover to light has fallen off twice (two different fans) Stealth and Belair. What can be done to prevent this problem ?
Both of these fans have a keyed light cover that is pushed in and twisted to lock into place. As you twist the cover into place you should feel it drop slightly when it is past the lock tabs. When locked in it is impossible for the cover to come fully off in normal operation. There are tabs in the lamp cover that prevent it from coming all the way off. To remove, lift slightly and twist. Clockwise to install and counter-clockwise to remove. It helps to wiggle slightly when installing to fully tighten, and again for removal. Be certain that it is twisted far enough to clear the lock tabs on the cover when installing.
Jun 20, 2011 | Casablanca Fan (3232A) Ceiling
How do I replace the passenger side corner light and front side turn signal light?
Front Turn Signal & Parking Lights
Remove the 2 parking light housing retaining screws ...
... then pull the housing away from the vehicle far enough to remove the bulb socket from behind the housing. Turn the socket counterclockwise and pull
Push the bulb in the socket gently and turn clockwise, then pull the bulb out of the socket. Note the offset retaining ears on each side of the bulb
  1. Remove the screws from the lens and separate the lens from the headlight bezel.
  2. Remove the headlight bezel.
  3. Remove the screws from the turn signal housing and pull it out.
  4. Turn the bulb socket counterclockwise 1/3 turn and remove it.
  5. Installation is the reverse of removal.
Side Marker Lights
  1. Remove the screws from the marker lens and separate the lens from the headlight bezel.
  2. Pull the bulb from its socket in the back of the lens.
  3. Installation is the reverse of removal.
Feb 14, 2010 | 1997 Jeep Grand Cherokee
How to replace front turn signal housing
  1. On some models you will need to remove the headlight bezel mounting screws and the bezel.
  2. Remove the mounting screws for the lamp assembly.
Remove the mounting screws securing the lamp assembly
  1. After the screws are removed, pull the assembly from the vehicle.
  1. Disconnect the twist lock socket from the lens housing.
To remove the bulb, turn the twist lock socket (at the rear of the housing) counterclockwise 1/4 turn, then remove the socket with the bulb; replace the bulb if defective.
Newer Oldsmobile models have the turn signal separate from the headlamp assembly ...
... unlike the newer Buicks, where the unit is attached to the headlamp
To install:
  1. Install the electrical harness to the back of the unit.
  2. Position the signal assembly, then attach to the vehicle with the mounting screws. Tighten the screws to 54 inch lbs. (6 Nm).
  3. Insert the socket to the back of the unit, then attach the headlamp bezel if removed.
Feb 13, 2010 | 1992 Oldsmobile Cutlass Ciera
Change front turn signal light?
To install:
Oct 31, 2009 | 1990 Pontiac 6000
Stuck ignition cylinder 1992 ford taurus
It is not necessary to have the dealer do this, think of the cash! Though it does require patience and time. The pin you are supposed to push in goes into a slot when you have it in run position, since you cannot turn it to run you have to make a slot for the pin to go into, with a drill. Be very careful as you only have a 1/4" of play before you break a washer behind the cylinder. Once you have drilled out the key far enough to the pin hole you can take a nail set and tap the pin up, you can tell when the pin clears the housing, then it just takes wiggle, patience and tinkering to get the cylinder to slide out, keep the green washer and the metal slot washer. Metal slot washer goes in first with green plastic washer ontop of that with lock cylinder in last. You can play around with the new lock cylinder and washer before insertion to determin correct direction.
Here are official directions with inoperable lock cylinder. They say drill out retaining pin but it just spun in circles for me - I looked at new cylinder and saw how it worked. retaining pin needs a place to go.
Removal & Installation (Non-Functional)
NOTE:Use this procedure to remove ignition lock cylinder if key is missing or cylinder is frozen.
Disconnect negative battery cable. Disable air bag system. See appropriate AIR BAG RESTRAINT SYSTEMS article in RESTRAINTS. Wait at least one minute for air bag back-up power supply to deplete. Remove steering wheel. See STEERING WHEEL . Using a 1/8" bit, drill out retaining pin located below lock cylinder on housing. DO NOT drill deeper than 1/2".
Using channel lock pliers, twist lock cylinder cap until it separates from lock cylinder. Using a 3/8" drill bit, drill down center of ignition lock key slot about 1 3/4" until lock cylinder breaks loose from its base.
Remove retainer, washer, and lock cylinder gear from housing. Remove metal shavings from lock cylinder bore. Replace housing if damaged. To install, reverse removal procedure. Connect negative battery cable. Check air bag system for proper system operation. See appropriate AIR BAG RESTRAINT SYSTEMS article in RESTRAINTS.
May 14, 2009 | 1992 Ford Taurus
Ge profile washer water will not drain out
Hi jmom,
This one is simple to do but hard to explain. Your drain pump has most likely ingested something that it shouldn't have and locked up.
SAFETY TIP: UNPLUG THE WASHING MACHINE or risk a funky new hair-do...
You'll need;
1.) A "Shop-Vac" (that'll vacuum water)
2.) Large Pliers or Channel Locks
3.) 7/16" nut driver or socket
4.) putty knife
5.) Flashlight
6.) Phillips screwdriver (maybe you'll need it)
Start by removing the front panel. Shine your flashlight into the gap between the top and fron panels. You'll see a couple of clips in there about 3" in from either side. Use your putty knife to slide into the gap and depress these clips while at the same time pulling out on the top of the front panel. Do this one side at a time. Now the front panel will rotate out about 45 degrees and lift off of the 2 clips at the bottom. Set the front panel aside.
Now look on the bottom panel (the floor), you'll see something like this down there. It's got 2 hoses and 2 wires on it. Remove the wires and set them aside.
With your Pliers, pinch the TOP hose clamp and slide it up the hose a few inches. DON'T REMOVE THE HOSE JUST YET. Now grab the Shop-Vac 'cause it's about to get real wet around here.
OK, fire up the vac and have the hose real close to the hose you just removed the clamp from. Now GENTLY but firmly start pulling the hose off of the pump. What you're trying to do is get the hose far enough off the pump to start leaking BUT not all the way off (all the way off would cause a flood... bad thing). If the shop-vac gets too full, just push the hose back onto the pump, go empty the vac. and repeat this until there is no more water in the washer.
Now that the washer is empty, remove both hoses from it and remove the bolts securing it to the floor. You have the pump in your hand now... cool! Look in the intake, the big hole in the front. You will probably see the culprit in there. Try to dig it out. If you can't, then do this... use a pen and make a mark where the pump housing meets the pump motor. Like, make an "X" across both the pump and pump housing (this will make sure that it's lined back up correctly after the next step). Now use your phillips screwdriver and remove the 3 screws holding the housing to the pump. Then remove the pump housing. Now you can get that little bug-a-boo that locked up your pump!
All ya gotta do now is rebuild ever thing in the reverse order! Easy Breezy, right? Should be an hour to an hour and a half job, but worth it! My pump repair charge is $129.65 plus a $32.50 service call. Sounds like alot, right? It's not if you are an expert, hehe ;-)
Let us know how it turns out, OK?
SG
Mar 23, 2009 | Washing Machines
Can't get headlight out of a 2003 Saturn L200
Try twisting it alittle bit more, sometime you twist them to far or not enough.
Feb 11, 2009 | 2005 Saturn VUE
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
