Question about Brother HL-2040 Laser Printer
Brother 2040 yellow toner light on & won't print. Toner just replaced 8 weeks ago. Printer purchased 6 months ago.
    President:
  • 2,306 Answers
You have a one year warranty with Brother if you need repair. You might shake the toner, or put a small electrical tape over the little round windows on the toner cart. to use the rest of the toner, and press the go button 3 times to print the report that tells you how many prints you've made, you could just be out of toner again...
Posted on Feb 03, 2010
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
My brother hl 2040 the tone light is on and dont allow me to print
It indicates your toner is finished and you need to replace with a new toner. Take out the toner & drum unit, on the left there is a opening which allows a beam to pass through to check toner level. There might be some toner left, for emergency printing block the opening with a piece of small paper and the light should go off for temporarily printing.
Dec 01, 2009 | Brother HL-2040 Laser Printer
I have 3 Brother HL-20040 laser printers but 2 of the 3 show the toner (yellow) light with good cartridges. Is this a common problem? Is the sensor bad? Do I junk it for another which I can purchase new...
Could be a bad sensor., but if you put a small piece of electrical tape over the windows on each side of the toner cartridge, ti will think there's toner and the light should be out. When prints come out blank, it's time for more toner...
Oct 28, 2009 | Brother HL-2040 Laser Printer
I have a brother 2140, I have replaced the toner car, the yellow light still comes on and the printer will not print
Remove toner/drum unit, remove toner by itself...remember to shake the toner right-left to loosen the toner before putting back in the unit. To reset the printer before you replace the toner/drum, and with the front door still open, hold the GO-Control button down until all lights are on, then let go, reinstall the toner/drum, & close up front door. Power off & back on and you should be set.
Oct 21, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Please describe your Brother HL-2040 Laser Printer problem
Yep this will always happen if your just using a replacement toner. They will be depleted faster compared to the original Brother toner.
Make sure you replace your toner with the original Brother toner.
Aug 24, 2009 | Brother HL-2040 Laser Printer
Yellow Toner Light Flashes - won't print
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 22, 2008 | Brother HL-2040 Laser Printer
New toner cartridge but prints way too light
where they refilled or third party cartridges? If so try a name brand. It could be the high voltage board or the laser aperture
could be dirty.
May 29, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Printing With Strange Gray Marks on Back of Paper
Sounds to me like the toner - that is the toner cartridge has the wrong toner in it. The drum should be OK - clean it up first and then use a genuine toner cartridge OR you can buy our refill kit on eBay - search for Brother HL2040 - michellem6123
Oct 16, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
328 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
