Question about Canon Office Equipment & Supplies
Paper stuck under fuser. how to remove paper/fuser
  • Anonymous Mar 21, 2014
    Paper became stuck in copier and now I cannot remove the portion that is stuck
    Scholar:
  • 69 Answers
Occasionally a serious paper jam can require partial disassembly of the fuser. Don't try this with the power connected. Specialist support may be required.
Posted on Mar 06, 2010
Lexmark E460dn paper stuck
If the paper is stuck on the fuse, I am assuming you mean the fuser. You will probably have to replace the fuser. You can remove the fuser and try to remove the paper and then reinstall the fuser. Could be a sticky sensor as well.
Apr 12, 2014 | Lexmark E460dn Laser Printer
Open the fuser for FS-C2126 MFP
there is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
Jan 17, 2014 | Kyocera FS-C5030N Led Printer
Ml-2160. How can I remove small pieces of paper from inside?
Generally paper is stuck either in the middle section or at the back near the fuser. Remove Toner cartridge and open rear door, if it's stuck coming out of the fuser, pull paper through from the back. Make sure to let the machine cool down first as the fuser is very hot. Remove any small pieces of paper from the front if before the fuser.
Jul 01, 2012 | Samsung Office Equipment & Supplies
Paper is stuck under the thermal unit and cannot be removed. The unit probably has to be removed to get at the paper and we need instructions how.
First you must remove the cover for the duplexing drawer below the fuser drawer. It will allow you to fully extend the fuser drawer to remove the fuser unit. You have to remove the 3 front covers of the fuser drawer, remove the three black screws that secure the fuser motor, then the yellow cover to access then two screws that secure the fuser unit to the drawer. But you must unplug the connectors you see in front of the fuser unit. I believe there are 5 connectors that need to be unplugged. Don't forget to unplug the connector below the fuser unit. This is the sensor that tell the fuser shield its home position. You fully extend the drawer by looking at each side of the drawer and push in the leaf springs you see and pull the drawer out further. Remove the two screws you see on the top of the fuser and gently remove the fuser unit. Take your time and all should go well.
Jan 15, 2011 | Canon imageRUNNER 5570 Copier
Small pieces of paper are stuck and cant be reached
Paper is probably stuck under the fuser, follow these instructions to remove the fuser:
Fusing Assembly Removal and Replacement
1. Remove rear cover:
a.) Extend input extender assembly
b.) Remove three screws
c.) Separate the rear panel from the main cover, pulling the lower corners away from the printer first. Then,
insert small flathead screwdriver into the openings at the top upper corners releasing two tabs,
remove cover.
2. Remove EP door assembly
a.) Along the left door hinge there is a flex point, firmly press tab inward to release door.
3. Remove main cover
a.) Remove rear cover
b.) Remove EP door
c.) Remove memory cover
d.) Remove two screws from top of printer
e.) Grasp two lower front corners of printer and pull gently outward, lift cover straight up and off
4. Remove fuser
a.) Remove exit roller (unlock white bushings on either end)
b.) Remove right hand cartridge guide (depress one locking tab and slide forward)
c.) Remove two screws from delivery assembly (fuser cover) and remove
d.) Remove two screws from pressure plate, (metal) unlock two retaining tabs and remove
e.) From right side of printer, remove cable guide, and fuser cable from DC controller
f.) From left side of fuser, remove thermistor cable (white) and remove fuser
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 02, 2011 | HP LaserJet 5L Printer
202 paper jam
I have this problem too, but the 2 sensors on the fuser are not stuck and seem ok to me. Any other suggestions?
Mar 06, 2009 | Lexmark T632 Laser Printer
Paper stuck in fuser.
It's fairly straight forward but you may find a service manual handy before you start. Get one HERE.
Jun 18, 2008 | Epson Aculaser C1100 Printer
Paper stuck in roller
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the control panel button.
Mar 31, 2008 | Brother HL-2040 Laser Printer
Paper jam
There is a sensor in the back that lets the printer know the paper has exited the fuser. It is probably broken off if paper is getting stuck back there.
Also check for paper remnants that are jammed. This may require removal of the fuser.
Mar 13, 2008 | Dell 1700n Laser Printer
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
71 people viewed this question
old marine
old marine
