Question about Sewing Machines
The thread got wound and tanged underneath the bobbin winding system of my Brother SE350. Can I just take it apart?
  • grubb_joey Feb 03, 2010
    The solution presented seems to be for a sewing machine not an embroidery machine. Please take a look at page #26 of the first manual at this link:
    http://welcome.solutions.brother.com/bsc...
    It says to just unwind the thread opposite of the direction that it was wound, but the thread is tangled under the bobbin winder and will not come off that way. I have tried to get tweezers underneath the bobbin winder but there is very limited space and it appears the only way to get to it is to take the case off the machine. Can you help out with this or should I talk to a service center?
    Not on the same page here. The place where the bobbin was tangled is nowhere near the needle plate or where the needle is located or where the sewing/embroidering even takes place.
    This particular machine has a feature on the top right of the machine where it will automatically wind a bobbin for you, then you take the newly wound bobbin and place it under the place where the needle operates. When the winding process was taking place it somehow missed the bobbin and went underneath the bobbin winder seat. It is so entangled that you can't just manually unwind it without physically taking the case apart on the machine.
    So, the question I have now is if I take the screws out of the back and pull this case apart to get under the bobbin seat are there any issues that this might cause that I need to be aware of ahead of time?
    Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. When a machine stops operation due to tangled thread, do not turn the pulley by force. If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly. You’ll need to remove a needle plate and cut the tangled threads by scissors or cutter. Also when you thread the machine do make sure you have the presser foot up so the thread goes between the tension discs, top tension between 4 and 6 normally, make sure the bobbin in the correct way round, you should be able to pull the thread through the bobbin case with some resistance, if it is too loose you will need to tighten the screw clockwise on the bobbin case, if it is too tight you will need to slacken it off a bit, remember the thicker the thread the tighter the tension becomes and even worse if you do not use a mercerized thread, if you need to check the top tension, with the presser foot down put your left thumb just above the eye of the needle and you should only just be able to pull the thread through.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    First thing the solution was for your machine not another machine. Secondly, as I said earlier you’ll need to remove a needle plate and cut the tangled threads by scissors or cutter. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Yes, you can open the bobbin case and nothing else will happen. You'll be able to untangle the thread from the bobbin. However, if still the issue is not resolved, then you'll need to contact the local repair tech. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
I have a brother model XL-5500 sewing machine but I do not know how to wind elastic thread onto the bobbin please help me
Generally, elastic thread should be hand-wound onto a bobbin to use in a sewing machine. This allows the elastic thread to be wound without any stretch incorporated before stitching.
Feb 22, 2016 | Brother Sewing Machines
How do I wind sharing thread onto a bobbin on a LX-5500 brother sewing machine?
Generally, elastic thread should be hand-wound onto a bobbin. Hand winding allows the elastic thread to be wound onto the bobbin without any stretch prior to sewing.
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
My white thread from bobbin shows thru embroidery
flip your bobbin
when I hold my bobbib in my right hand and pull the thread with my left hand the bobbin spins counter clockwise, this is how i put it in the machine
Do you wind your own bobbins if so make sure you wind evenly
I order a box of 100 pre wound bobbins from Brother
Sep 10, 2009 | Baby Lock Esante
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Brother XL-5130 Sewing Machine
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_5130_5232_5340_EN_208.PDF
Feed the thread thru one of the holes (the hole that will be on top) going from the middle of the bobbin thru to top. pull up about 2 inches, push the bobbin over to start winding and before pressing the foot, hold the 2inch piece sticking up. HOLD TIGHT. after the thread is wound about 25 times, stop winding and snip the 2inch piece level with the top of the bobbin. Finish winding.
Apr 13, 2009 | Brother XL-5130 Mechanical Sewing Machine
Sewing machine has bobbin thread would around winding shaft
If the bobbin is on correctly try crossing the thread before going through the tensioner which should solve this problem and also a more evenly wound bobbin.
Dec 17, 2008 | Brother LS-2125 Mechanical Sewing Machine
E6 error on CS-100, thread underneath all knotted and tangled, makes grinding sounds.
Your bobbin is not wound correctly. Check and see if your bobbin thread is wound to loose or unbalanced.
Oct 25, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
