Question about Contessa Ice Cream Makers
How do I get the cover off my Contessa TS-061 to enable me to replace the water pump?
Can you replace just the body part of the water value instead of having to recover and recharge the system?
Yes you can. I have never seen the charged side of the valve go bad. Remove the 4 screws (usually T-20 Torx or phillips) on the "bell housing" side, and replace everything besides that part.
046686-ntrk102vrythapb4yqnobf12-2-0_0.jpg You can order the water valve here if you need it.
046686 Water Regulating Valve 3 8
Jul 25, 2015 | Taylor 794-27 Soft Serve Twin Twist Water...
Pump cutting off
the pump is not suppose to run all the time.it should cut off until you pull draw handle . when handle is pulled pump should run for ten seconds or so.
May 06, 2012 | Taylor 8756-33 Soft Serve Two Flavor Ice...
Hello. We have Taylor c712 with air mix pump. After 1 hour (18-25 cups) product is overfreezed(have a grainy and icy texture) and temp of tthe product between 14-15 F.
it is over freezing, you need to have the viscosity adjusted and also make sure you are removing all the water when you are priming unit.
Sep 05, 2011 | Taylor Ice Cream Makers
I have a sterling ice cream freezer the can has rust spoy-ts in it can i get a new can
Is there a Ace Hardware store in your area? If anyone can get you a replacement (aside from the manufacturer) it will be Ace.
These rust spots ... outside or inside? If outside ... use the can as is.
Thanks for your interest in FixYa.com
Jul 05, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
Contessa 450 sewing machine is not forming a stitch
have you checked the timing? needle must be in full down position at the same time shuttle is in the up position.
May 18, 2010 | Contessa TS009AS Ice Cream Maker
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
No accumulation of ice
Check to see if your condensor coil is clean, use an air compressor or other source to blow thourgh the coil,dont just brush it off. newer refrigerant charged systems need as much air flow as possible to work ,also make sure the cover is on the condensor section while the ubit is in nrmal operation. try setting the cube size to lowest setting and let run for 24 hrs. Let me know if you need further assistance.
Nov 16, 2008 | Ice Cream Makers
Emerson IM90 Portale Ice Maker
My friend bought this item last week at Target for the $99 sale price. The reviews were all horrible about the red light (add water) indicator going on after the first or several first ice cube runs and never going out. About 40 out of 60 reviewers had this problem. We experienced it right after the first run when the ice cube full light went on. We emptied it and the add water red light was on. I looked all over the web for a solution and only found one that suggested tilting the unit backwards for 45 degrees and that would magically reset the light. It did not after several angles, light taps and basic shaking. Since there was no alternative and everyone who returned it also got the exact same problem with the new replaced model - we decided to open it up and investigate.
The electronics diagram is on the back of the machine and tell you where the water indicator is. We took it out (an inch long black tube along the water pump and backflow valve) and dried it completely. The cycle still had the red light. We submerged it completely in water and the red light still went on saying that the unit needs water. We determined that this is the bad part and the water indicator is faulty. We cut it out and joined the two wires. IT ALL WORKS NOW FLAWLESSLY. You only have to shut the unit off when you leave since it will ocntinue to run if out of water. If you're looking for a quick mechanical fix and have a unit that works when you need it and you are around - this isthe fix.
Aug 23, 2008 | Ice Cream Makers
Danby icemaker not pumping water
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Jul 16, 2008 | Ice Cream Makers
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Ice Cream Makers Logo
138 people viewed this question
Top Contessa Ice Cream Makers Experts
ray gallant
Are you a Contessa Ice Cream Maker Expert? Answer questions, earn points and help others
