Question about Brother IntelliFax-2820 Laser Fax
How do you turn down the ring volume? How do you change the setting to answer on the first ring?
I went to your site because it was advertised as FREE. I guess I was wrong.
Thanks for the assistance!
Posted on Feb 04, 2010
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Change ring tone
Go to settings sound to change volumes. Under ringtone in same previous screen you can change
Jan 27, 2015 | Cell Phones
Phone will not ring
Is the ring volume turned up? Turn the ring volume up by attaching and plugging in the cord for the answering machine. Next leave the handset on the phone and press the up volume button with the plus(+) sign next to it.
Picking up the handset while pressing the up or down volume button will increase the voice volume.
The answering machine does not have to be on for this to work.
Feb 09, 2011 | GE 29870GE1 Corded Phone
How do i change the number of rings before it goes to answering machine. We would like 5 rings instead of 3. Also sometimes when people call in it says our system is not set up yet.
Make sure the answering system is ON.
Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
Press key [9] to enter Ring to Answer menu on handset.
Use the CALLER ID-VOLUME (up/down-arrow) button to choose 5 rings.
You can download the manual here.
Feb 06, 2011 | GE 25942GE2 Cordless Phone System
How do I turn up the volume to hear people talking louder...all I can find is how to turn up the ringer volume...
On most mobile phones this is a setting hidden somewhere in the "Settings" or "Options" menu, but the easiest way to to fix it is with a simple phone call. While you are currently on a call with another person, you can turn the speaker volume up using the same button to turn up the ringer volume.
Note that this will only work if you try to turn up the volume while the phone on the other end is ringing or you are currently connected on a call.
Aug 06, 2009 | Cell Phones
HOW TO CHANGE THE NUMBER OF RINGS BEFORE THE MACHINE ANSWERS?
This is for a 5.8 GHz uniden. Hit "menu/clock" then use volume up and down key to select number of rings and then below "menu/clock" hit "set". That should it.
Apr 18, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Hangs up after 2 seconds into recording message
SETTING THE RINGS TO ANSWER
This setting allows you to select the number of rings before the answering system answers a call.
At idle status, hold down the volume "UP" button over two seconds to enter the ring times setting of answering. The answering system announces, "ring time two" (the default is 2).
To change the rings to answer, press and release the "PREVIOUS" button (<<) or the "NEXT" button (>>) and the answering system announces a number such as "2, 1, toll save, 9...” OR "2, 3, 4...", if you select the toll save and the digit LED light shows a “γ”, the answering system announces “toll save”.
After choosing a number, press the “PLAY/STOP” button one time to store the rings to answer, and the answering system confirms the setting and returns to the idle status.
NOTE: when the machine fails to operate properly, just unplug the power for 10 seconds, and redo the settings.
Aug 03, 2008 | Emerson Em1200 Answering Machine
My razr does not ring when someone is calling
volume may be turned off or down or it is set on silent. go to settings, go to ring styles, select style and edit/add. scroll down to the ringer of choice and hit select. hopefully that will work. also try the volume on the side of phone. by pressing top left button, you can change ring styles that way.also controls volume.
Jun 27, 2008 | Motorola Audio Players & Recorders
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Mar 24, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Brother IntelliFax-2820 Laser Fax Logo
260 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
