Question about HP Pavilion tx1410us Tablet PC
How can i remove the screen - HP Pavilion tx1410us Tablet PC
My acer laptop have some problem
after starting show me messess Press F2 & F12 error
Posted on Feb 04, 2010
Inner screen is crack on a kurio
Kurio 7 Screen Replacement
Written By: Eric Rice (and 6 other contributors)
Comments: 2 Favorites: 5 Completions: 12
Main guide photo
Difficulty
Moderate
Steps
12
Time Required
30 - 45 minutes
Sections
Back Panel
4 steps
Kurio 7 Motherboard Removal Guide
5 steps
Screen
3 steps
Flags
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Introduction
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Tools
Buy these tools
Phillips #00 Screwdriver
$6.99
Buy
iFixit Opening Tools
$1.99
Buy
Parts
Kurio 7 Replacement Screen
Available for sale on Amazon
Buy
Step 1 Back Panel
Begin by removing the rubber cover from the Kurio 7.
Add a comment
Post comment
Step 2
Remove the four 30 mm Phillips #00 screws from the outer case.
Add a comment
Post comment
Step 3
Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
Be careful not to break off the tabs that hold the front cover and the back cover together.
Add a comment
Post comment
Step 4
Once all of the tabs are removed, the back cover should come off easily.
Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Add a comment
Post comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Buy Now
Step 5 Kurio 7 Motherboard Removal Guide
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Be sure to work the card carefully and slowly around in order to not damage, break, or deform the battery.
Carefully set the battery aside.
Add a comment
Post comment
Step 6
Use a Phillips #00 screwdriver to remove the eight 40mm screws holding the motherboard in place.
Place the screws aside in a container separate from the other size screws. You will need these later.
Add a comment
Post comment
Step 7
Place the plastic opening tool on the base of the black ribbon clip and pull up, like a lever, to release the mount. This should release the clip holding the ribbon to the mount.
Pull the ribbon out of the mount.
Add a comment
Post comment
Step 8
There should be masking tape on the yellow ribbon. Pull the tape off of the motherboard and wrap it around the yellow ribbon.
Do not pull the tape completely off the motherboard, as it is used to protect components on the ribbon.
To remove the ribbon from the mount, follow the same steps in Step 3.
Add a comment
Post comment
Step 9
Pull back the ribbons and put the battery near the bottom of the Kurio.
The motherboard is now removed so that other components can be worked on.
Add a comment
Post comment
Step 10 Screen
Flip motherboard down near base of device.
Be careful not to pull out any wires when moving the motherboard.
Add a comment
Post comment
Step 11
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Be careful not to pull too ******* the motherboard while doing this, as there are still many wires attached to the body of the device.
Add a comment
Post comment
Step 12
You have successfully removed the screen!
Pull the screen out from the casing.
Jan 07, 2018 | Tablets & eReaders
How to delete extra pages
    1. Remove Home Screen Panel
      1. From a home screen, pinch in on the screen. Place two fingers on the screen and bring them together.
      2. Select and hold the appropriate panel then drag it to Remove (located at the top).
      Add/Remove Home Screen Panels - Samsung Galaxy Tab 2 ...
      www.verizonwireless.com/support/knowledge-base-63229/ Verizon Wireless
    Feedback
  1. How to Manage Home Screen Pages on the Android Tablet ...
    www.dummies.com/.../how-to-manage-home-screen-pages-on-the-andro...
    To edit Home screen pages, pinch the Home screen: Touch the screen with two fingers and drag them together. You can then manage Home screen pages. Generally speaking, to rearrange the pages, long-press and drag it to a new spot. When you're done, touch the Back or Home icon.
    www.verizonwireless.com/.../knowledge-base-63229/
    Verizon Wireless
Jan 09, 2016 | Tablets & eReaders
How to remove an icon from home screen
On most Android tablets, you simply press and hold the icon until the screen changes modes (to arrange). Then you should see an option to delete/remove at the top of the screen. Just drag the icon to the top of the screen and it should leave the home screen.
Nov 18, 2015 | Tablets & eReaders
Black screen cant get menu
Hi Tracy..., last month my ipad got black screen also, all i have to do is.. I open it
slowly and carefully pull-up the touch screen,then i remove the LCD and at the back of LCD you can see the black plastic cover, carefully remove it,then when finish removing it, at left side there is flix ...that is the connection of backlights...
if you see that is broken that causes you the ipad turn black screen, all you need is to get a soldering iron and a lead then fix that 9 connections of flix one by one ..and after that, all parts that you remove return it carefully and restart your ipad..and you have your ipad now back to normal
Aug 23, 2015 | Apple iPad (16 GB) WiFi Tablet PC
How do I remove unwanted icons from screen on tablet?
depends on your device, on my asus I press and hold icon then drag to top of screen where a "remove" feature appears
Jan 10, 2015 | Tablets & eReaders
How to change glass screen o 10.1 trio stealth 2g tablet
The screen replacement is available at Amazon. As stated in the description, no instructions included. Nice set of tools included; most not needed. Installation is pretty intuitive; once you see the new screen, you realize that it attaches to the front bevel with adhesive tape, with one electrical connection. You must remove the broken screen basically by gently prying around the edges with tool of your choice. I did see a video of someone using a heat gun to soften the adhesive, but I dared not and used a small hairdryer on occasion. Lots of broken glass pieces will be created, wear safety glasses and work on a protected surface. If I were to do it again, I'd use a shallow cardboard box like the ones on the bottom of packs of soda. This will prevent glass escaping. Be VERY careful when working near the LCD screen, it does scratch easily. Don't worry about the cable, just cut it when removing old glass. Once all glass removed, the Trio will snap open with slight pressure on metal tabs. NO screws involved. Clean bezel well, remove old cable, install new one , reinstall the power and volume piece at the top and snap case together. Simply replace screen by removing adhesive tape and gently pressing screen it in around edges. I think the new screen works better than the original. Be sure both new screen and LCD are clean before the final install. That's how I did it; others might have a better way. Be patient and careful about all the broken glass and it should work fine. Good Buy for money, ships from China but does not take long to get to US. Tracking info is included with the shipping confirmation.
Oct 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
I have a Apple IPad 2. I want to remove a home screen Icon, how do I do this?
press and hold down the icon until you see it shaking and an x next to it then press the x and delete.
Mar 19, 2014 | Apple iPad Tablets & eReaders
Have to know how to open joytab
Use a rubber same as to remove iphone screen. Lift screen out opposite end to all the side switches. When screen removed it gives access to power board.
Dec 04, 2012 | Tablets & eReaders
Gateway TabletM280e screen broken. What is needed to replace and how to replace it.
Assuming the screen is physically cracked, you need to obtain a new screen, remove the screen bezel by popping off the rubber caps and undoing the screws under them. The screen is fixed into position by two rails with small screws holding it into place. Remove these and the screen will be freed.
Disconnect the VGA cable and the smaller two wire plug that connects the inverter to the screen, replace the new screen and re assemble
Mar 27, 2011 | Gateway M280E
HP Pavilion tx1410us  Tablet PC Logo
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
tosin_christ
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
