Question about Sony VAIO VGN-FJ270/B Notebook
What could be the real cause of MBR coruption on my hard disk SONY VAIO VGN-SZ79MN? What is the cause for no OS System found upon boot up of a brand new unit?
  • rcristuta36 Feb 03, 2010
    Pressing F8/ F10 was done by a customer care service man but to no avail. It says Can the installation repair be done using another OS Disk since there was no back-up disk yet of the Windows Vista OS which is built in with the unit? or can it be repaired using the XP OS Disk to recover the missing WIN32.dll file?
    Guru:
  • 194 Answers
When putting a new system online before configuring any antivirus or other security software opens up the system to immediate infection. It is possible that if you spent any amount of time online before properly configuring your Antivirus and/or firewall that your system was infected with a virus that manipulates your system to thinking the Windows installation has been corrupted. Running a installation repair on your windows installation will resolve the issue. Simply press f8 on startup and select use last known settings that worked, or you may need to use your disks to restore the system.
Good Luck,
NOLA Tech
Posted on Feb 03, 2010
  • Jesse Lohse Feb 03, 2010
    No you have to use the same OS version as is installed, but it does not have to be the Sony version. Did your system come with the Windows 7 upgrade DVD? I know newer systems that have Vista on it came with the upgrade DVD for free. I would recommend upgrading to 7 anyway since Vista is fraught with error.
    Good Luck,
    NOLA Tech
System crashed replaced hard drive now trying to load windows 7 but after bios loads we get a really weird glitchey screen and it says 'Operating System not found'
That message is because there is no OS on the disk. Press OK to agree the notice and then load the System Disk in your DVD drive and boot from there.
Dec 23, 2010 | Sony VAIO VGN-FZ260E/B Laptop
When i am swiching on the laptop it shows os not found
Dear Friend,
As there is no primary drive in this vaio, it boots form Hard drive. If OS on hard drive is corrupt OR HDD is bad then you will get such massage. Go to set up. Enable external booting option. Try booting the system from USB pen drive ( You have to make a bootable pen drive ). If it boots then you have to replace HDD.
Dec 05, 2010 | Sony VAIO VGN-UX280P Notebook
Sony vaio vgn series laptop - when xp os loading blue screen appears and display the msg hard disk drive not detected.
system not found in my experience generally leads to a damaged or loose hard drive, try to open the cover at the bottom side of the machine, and reseat the hard drive, if it still says system not found, get a 2.5 inch drive case, put your laptop drive in the case and connect it to another machine, if you can access the drive great! save all your files and once complete return the drive to your machine and try to reinstall the OS from a dvd then reinstall your files.. and if still having the same problem replace hard drive thanks.
Oct 26, 2010 | Sony VAIO VGN-NS135E/S Notebook PC
Vaio operating system not found.
first check that your hdd is detecting by your laptop.
i think you have removed mbr master boot record from your hard driver the soution is to create master boot record in your harddrive by using mbr commands.
May 06, 2010 | Sony VAIO VGC-LV110N PC Notebook
I have a operating system not found
This issue may occur if one or more of the following conditions are true:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
    Note Some third-party programs or disk corruption can damage an MBR.
  • An incompatible partition is marked as Active.
  • A partition that contains the MBR is no longer active.
Contact your hardware manufacturerYour best bet may be to contact the manufacturer of your computer or your hard disk. The manufacturer may have a utility that you can use to perform a more detailed scan for damaged areas of the disk and help verify the correct BIOS settings. However, be aware that the damage to your hard disk may be serious. Sometimes this means that your only solution is to replace your hard disk.
Mar 05, 2010 | Sony VAIO VGN-AR630E Notebook
I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Jul 21, 2009 | Sony VAIO VGN-NR160ET Notebook
Get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Apr 09, 2009 | Sony VAIO VGN-FJ270/B Notebook
Operating system not found
On my Sony VAIO Windows 7, I have got "operating system not found" error, to fix problem, Windows Boot Genius helped me finally!
Apr 09, 2009 | Sony Computers & Internet
Sony Vaio - old type
You can google boot disk for the os you have there are several sites you can download from
Dec 29, 2008 | Sony VAIO VGN-N250N/B Notebook
Sony VAIO VGN-FJ270/B Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
