Question about Maytag Neptune MAH5500B Front Load Washer
My washer clangs and dances like crazy!!!
I thought my struts had worn out, the front boot is also torn from this problem. New struts and front boot. Still appears to be posessed by the devil!! Is there a screen in the drain somewhere stopping some of the water from draining? This would make sense of my problem if the pump couldn't get all the water out of the machine, clothes stay wet and go nuts in spin. I will look myself and hope for a response if my search is unsuccessful.
  • Soundhound Feb 20, 2008
    This just in, no screen. Must be a burned out winding in the motor. Not the high speed, but a lower speed to centrifugally remove water for the pump to move out before the high speed spin. Fair guess?
  • Soundhound Feb 26, 2008
    Nop goodies in the drain. It was the motor which is still under warranty, however after calling Maytag, they told me that a service tech would have to do the service. I am an industrial air conditioning technician. I take car of roughly 40 acres under roof at a steel mill. Still they insist I must be stupid, and a tech must do the install. Luckily the parts guy heard my whole rant to Maytag customer dis-service and gave me the motor, still under it's 10 year warranty, at wholesale. The price was $153 before tax. Please advertise against Maytag if you can. Their service sucks. My washer works great now, the motor was the fix.
    President:
  • Maytag Master
  • 2,651 Answers
Although no screen , quite possible foreign debris( sock, bra underwire, washcloth or change in drain hose or pump itself preventing proper drainage in allotted time. open the hoses and have a look see
Posted on Feb 22, 2008
Clunk noise when turning
Check the cv shaft boots, if they are torn the grease inside will have come out and now the joints inside are worn out. Worn cv joints will cause noises when turning.
Feb 20, 2017 | Ford Taurus Cars & Trucks
Thumping noise coming from right front wheel well?
IT is probably the strut bushing that is worn, The one that you can't see
Oct 18, 2015 | Dodge 2011 Grand Caravan Crew
I have torn rubber on front struts at top where it connect into engine compartment
Replace them... the rubber boots protect the upper joint of the strut, corrosion of this joint will lead to excessive wear causing alignment issues. Depending on your mileage and the type of roads you drive on, it may well be time to replace the entire strut.
Apr 02, 2015 | 2007 Toyota Corolla
A loud metal to metal clanging noise in the front of the car
Are you sure the struts and strut bearings are installed correctly and all fasteners are tight? Did you check your stabilizer links? Did you check your stabilizer frame bushings? Did you check your tie rod ends? Did you check the lower ball joints? Did you check the control arm bushings? Did you check for loose or missing brake caliper bolts?
I am sure that a thorough inspecton of the front steering and suspension system will turn up something. However, it is really hard to accurately guess from this end without more to go on than just a "metal clanging noise"....there are way too many things that can fit that desription.
Apr 09, 2012 | 2006 Pontiac Torrent
Six year old Whilpool Duet washer on pedestal and level front and back still vibrates excessively and makes loud noise when spinning water out of machine. Is sitting on concrete floor. Have owned since new...
check the inner struts on the bottom of the tub you need to remove the front panel some have a split lower section so you can access inside where the struts are also check that the struts are not worn out hope this helps
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Periodic clunck in front end
A 2003 SUV will clock in over 80,000 miles.
It's time to inspect the shocks and struts.
The periodic clunck you hear in front end can cause by
mud guard boot to metal strut body contact
worn strut center post to body of strut contact
worn rubble linkage
or combination to all of the above.
I would take the SUV to a good car wash that has under carriage cleaning.
Let the SUV dry and inspect it someone who can compress the front end.
If the front of the SUV re-bound two times then the struts will need to replace.
Jul 08, 2010 | 2003 Nissan Murano
I also have a torn door boot. A repairman came
http://appliancejunk.com/ge/washer/31-9135.pdf
This manual will cover all service for your machine.
You can do it yourself.
Go to repairclinic.com for your parts.
Nov 09, 2009 | GE WBVH6240F Front Load Washer
Washer was jumping and dancing when it got to spin cycle
The only thing to check is to see that some struts behind is taken off. This is inserted to prevent the drum from banging around during transit; refer to your manual. Important.
Jan 12, 2008 | LG WM2487H Front Load Washer
Torn Door Boot
the way to replace it is you undo seal from front which might be a thin spring clamp behind the lip of the door seal it will be metal undo your lid look down the front of your washer to see the inside of the back of your door seal it will either be another bigger spring clamp or a screw clamp undo door seal will pullout replace backwards to how youve undone m8
Aug 13, 2007 | GE WBVH6240F Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
