Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA
My freezer no longer freezes. were do start to
My freezer no longer freezes. were do i start to locate the problem?
  • 4,793 Answers
Bin it. it is cheaper to replace than repair.other than the fuse that is.
Posted on Feb 05, 2010
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
Why isn't it freezing?
Hello friend, thanks for your inquiry!
From the information you have provided your Frigidaire freezer is no longer freezing and all the lights are on. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If this does not start your freezer would you be able to provide me with your model number? You can locate the model number on your serial tag which can be found on the inside wall. I look forward to assisting your further. -Matt
Feb 28, 2016 | Frigidaire Freezers
Freeze back up timer3beeps
signal means freeze cycle is longer than 60 minutes. Look for: stuck float, water valve leaking water into the sump, Hot Gas Valve leaking hot gas into the cold side of the refrigeration system. Start there.
Mar 06, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Slow ice production
that could be one solution. I would look at how long the freeze cycle is lasting. The machine could be cycling off and on via bin stat. Average cycles from start of freeze cycle to start of freeze cycle is usually around 25 minutes or so. If it is taking longer than that, you may have to dig deeper. let me know. Don't overlook a leaking water valve.
Aug 23, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My freezer is running but not freezing
Thermostats are usually located in the machine, lower right side facing it but sometimes the left side. More than likely you have a freon leak and the machine is starting to act like a fridge then a freezer.
Jun 05, 2012 | Freezers
I just bought a used (but never installed) wf 1061 (freezer with a wine fridge). the unit and dsidplay lights up as normal...but i don't hear the compressor starting...can it be in demo mode?...
Try this also:
Super freeze 5 seconds set desired temp press super frees briefly again then adjust the wine cooler temp press super freeze again briefly, Next press menu and select normal. Then press menu again. To exit press super freeze again until it no longer blinks.
Kelly
Aug 28, 2011 | Freezers
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Maytag Freezers
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
No longer freezes
The evaporator fan in the back of the freezer blows over the cooling coils. Those coils are typically hidden from view behind a panel.
The problem you describe would lead me to suspect that the coils are iced over. That is why there is some cold, but not enough. The fan is blowing over a block of ice. An overfilled freezer is another possibility.
Iced over coils may be the result of a malfunctioning defrost system, a plugged drain tube, a poor seal on the door seals to the cabinet resulting in a lot of moist air entering the freezer (or fridge) or the refrigerant level is under pressure (needs more refrigerant added).
Most refrigerators never need refrigerant added, but after 25 years, it could be that yours does. However, it can only be done by a pro, and it probably isn't worth investing that kind of money in such an old fridge.
I recommend you start by unplugging the fridge and inspecting the coils inside the freezer. If they aren't iced over, then the door seals may be still be the problem by letting in warm air.
Jan 19, 2009 | Avanti Freezer CF62
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
216 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
