Question about WYSE Winterm S30 Network Terminal
Wyse S30 resetting to factory defaults
Hi, I have a couple of Wyse S30's that keep reverting back to the factory default settings on their own. I know this is realted to a Flash problem, but does anyone know how to correct this? Thank you.
Tapping the "G" key upon bootup
Posted on Mar 23, 2010
Enter admin mode
I have 10 unit that belonged to Chase back, and it tries to auto connects to there DNS. I tring to reset the unit to factory default with out any success. I have tried just about everything. The remote connect flash don't work because it boot into auto connect with CHASE logo, then fails finding DNS screen. I was able to access the bios, and get into the control panel. I still looking for a way to reset to factory default without success. G, Control+G, Fi report has been used to gain access, but can't change the boot process from logging as CHASE with the auto connect. If you have a solution......
Nov 13, 2010 | WYSE Winterm S30 Network Terminal
What is setup password
you can dawnload it from the manufacture websit.Just send a mail to request for password with your products no.
Sep 11, 2009 | WYSE Winterm S30 Network Terminal
Wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
WYSE S30 RESOLUTION SETTING TO HIGH
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
Password
The default password for netgear router is "password" and default username "admin"
If if this would not work then you need to reset the router by pressing the reset button at the back for 10 seconds and then unplugging the power foranother 10 seconds and then plugged it back it, this will revert the username and password back to default.
NOTE:IF you reset the router all settings will revert back to factory settings.
Sep 19, 2008 | NetGear WGR614 Wireless Router
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
The display settings are not valid with the monitor. Either you are using a new monitor or you have changed the settings. If you are using a new monitor, swap with the old monitor and configure the appropriate refresh rate for the new monitor.
If you have changed the settings you may need to either reset all default settings, or setup a parallel unit and use the same key strokes to change the display settings on the problem unit.
Cheers..
Apr 02, 2008 | WYSE Winterm S30 Network Terminal
Hardware reset
Double-clicking the System icon in the Control Panel opens the System Info dialog box.You can use this dialog box to allocate thin client memory and reset the thin client to factory defaults.
The General tab contains a check box that allows you to reset the thin client to factory defaults (the check box is active for administrators only).
You can reset the thin client to factory default settings by selecting the *Reset the terminal to factory-default property settings* check box (the System Settings Change message displays and you can confirm and follow the instructions provided to reset the thin client).
Mar 01, 2007 | WYSE Winterm S30 Network Terminal
WYSE Winterm S30 Network Terminal Logo
2,264 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Tim Hunt
Tim Hunt
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
