Question about Whirlpool Duet GHW9150P Front Load Washer
The code HF came up - Whirlpool Duet GHW9150P Front Load Washer
  • 39 Answers
I believe the code HF is telling you that you are not getting hot water. Check faucet in back and make sure water is turned on at both hot and cold valves. Even if you only use a cold setting, the hot water needs to be turned on. Also check washer fill valve screen. Turn off water and take off hoses at washer. Inside valve are sceens that may be clogged.
Posted on Feb 03, 2010
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
Tip
Convert/Import, Edit Canon VIXIA HF Series Video to Mac, iMovie, Quicktime
Canon VIXIA Camcorder has a good reputation for its small size, recording video in full HD quality, lightweight, etc. Just like popular Canon FS series camcorder, Canon VIXIA HF series Camcorder is a large family including VIXIA HF R-series like VIXIA HF R10, VIXIA HF R11, VIXIA HF R100; VIXIA HF M-series such as VIXIA HF M30, VIXIA HF M31, VIXIA HF M300; VIXIA HF S-series like VIXIA HF S10, VIXIA HF S20, VIXIA HF S21, VIXIA HF S200, and some other popular VIXIA types such as VIXIA HF10, VIXIA HF100, VIXIA HF20, VIXIA HF200, VIXIA HG21, VIXIA HG20, etc.
Most of Canon VIXIA HF series camcorders record videos in AVCHD MTS files. If you want to share these AVCHD MTS files with family or friend on Mac, you may cannot directly playback these MTS videos with your Mac, iPad, iPod, iPhone, or Blackberry. If you would like to customize Canon VIXIA HF video on Mac, you may cannot directly edit MTS videos in iMovie, FCP, FCE, etc. What should we do about this? The best solution is to transfer Canon VIXIA HF video to Mac supported video format such as MOV, MP4 that are aslo for iPad, iPod, iPhones, Blackberry, PSP, etc.
AVCHD Converter for Mac is the best choice for you to convert Canon VIXIA HF video to MOV, MP4, AVI, 3GP, MPEG-4 for Mac so that you can import these AVCHD MTS/M2TS files to iMovie, iTunes, iDVD, FCP, FCE etc for editing. Besides, this Canon VIXIA Video Converter for Mac also has powerful editing function like trim video length, crop video, set video brightness, contrast, and saturation, and customize video/audio output settings, etc.
Now, easy tutorial for you to convert Canon VIXIA video to Mac OS step by step.
Step One: Import Canon VIXIA HF Video to Mac AVCHD Converter
Firstly, you need to copy your Canon VIXIA video to Mac and launch AVCHD Converter for Mac, then you can click "Add File" to upload your AVCHD MTS files on Mac.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS.
Step Three: Convert Canon VIXIA Video to Mac
Click "Start" button to convert Canon AVCHD MTS files for Mac. After conversion finished, you can edit your converted MTS, M2TS files with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 13, 2010 | Computers & Internet
Ideal icos 18 fault code HF
According to pages 47-50 of the install guide, section on FAULT FINDING, the alternating H and F indicates Flame Detection Short Circuit Error. Actions are: Remove flame detection electrode terminal from PCB. Test for continuity between 2 terminal pins? If YES, replace flame detection electrode. If NO, replace PCB. If you need more diagrams and full guide go to http://idealboilers.com/installer/wp-content/uploads/sites/2/2013/08/203318_inst.pdf
May 19, 2014 | Water Heaters
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite washing machine
This code means its not getting a sufficient water supply. I was doing a cold wash and noticed it was sucking down some hot water, so shut off the hot. MISTAKE, after a little bit the HF code came up. Apprently it likes to decide for itself just how cold is cold. Darned Computers.
To make a short story long, when I shut off the hot, it apparently shredded the washer and sent the remnants down to the little filter thingy at the washer itself, whereupon they reassembled themselves into a clog, once again giving me the HF code.
(Check your user manual Troubleshooting section. I think it says to press Pause/Cancel twice)
Mar 30, 2008 | Kenmore Elite 45986 Front Load Washer
Hf code
You need to be more specific. When does the code appear? Does the machine start?
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
274 people viewed this question
Dan Webster
Dan Webster
Sal De
