I NEED THE PROGRAM CODES FOR REALISTIC SCANNER
3 Suggested Answers
SOURCE: Realistic pro-2011 direct entry programmable scanner 20 channels
PRO-2011 Programmable Scanner (200-0118) Operation Faxback Doc. # 34694 PROGRAMMING FREQUENCIES 1. Select the desired channel in one of three ways: (a) Press [MANUAL]. Continue pressing until the display shows the desired channel. Press [PROGRAM]. (b) Press the desired channel and [MANUAL]. Press [PROGRAM]. -- or -- (c) Press [PROGRAM]. Press the desired channel. Press [PROGRAM]. 2. Type in the Frequency. NOTE: If you are uncertain about specific frequencies in your locale, RadioShack's "Police Call Directory Including Fire & Emergency Services" is an excellent reference. 3. Press [ENTER]. To program the next frequency, press [PROGRAM] to advance to the next channel Repeat the same steps to add more frequencies. HINTS AND TIPS FOR PROGRAMMING When you make a mistake while entering a number, press [CLEAR] and re-enter the correct frequency. If you enter a frequency that is outside a PRO-2011 band range, Error indicator lights. Press [CLEAR] and select another frequency. Any frequency within a PRO-2011 band range will be accepted. However, the frequency that can be stored into PRO-2011 memory is in 5 kHz step in the VHF bands and the 12.5 kHz step in the UHF bands. The scanner will automatically round off the entered frequency to the closest valid frequency. For example, if you enter 145.234 MHz, the PRO-2011 will accept this entry as 145.230 MHz. Or the entry 398.263 MHz will be treated as 398.262 MHz. The tuning range of your PRO-2011 is permanently stored in the microprocessor chip. There's no way it can be extended or altered -- even by a skilled electronics technician. So if you try to enter a frequency not in the PRO-2011's tuning range, you'll get an error message every time. If you want to change the frequency entered for a specific channel, enter the new frequency over the old one, following the steps in "PROGRAMMING FREQUENCIES" (above). (IR-09/25/96) Privacy Policy
Posted on Mar 05, 2009
Its easily done. If you go to Googles site, and put iowa scanner codes in the search space, one of the choices there will be >>>>>
http://www.radioreference.com/forums/iowa-radio-discussion-forum/36607-ultimate-iowa-scanner-frequency-page.html
Posted on Apr 16, 2009
How do i program realistic pro-59 scanner
http://support.radioshack.com/support_electronics/8567.htm
don't know what you will pickup. Nearly all law enforcement, ems, fire have gone to digital trunked systems that are encoded. The above link has a link to the operating manual. You will need to know the frequency of whatever you are wanting to listen to.
Aug 28, 2016 | Radio Communications
I need codes for my realistic pro 2023 scanner
Codes? Assuming that you're looking for frequencies, you can find a comprehensive database of active frequencies in your area, and a lot of other useful scanning information by visiting:
www.RadioReference.com
Bill B.
Listening in since the 60's
Dec 25, 2010 | Uniden BCT7 Base Scanner
Realistic patrolman pro16A radio scanner, do not know how to program freq, this scanner does not have crystals, does anyone know how or have a manual??
I have checked several sources, and they all show that the PRO-16A is a 16-channel VHF/UHF CRYSTAL scanner. Remove the bottom cover and you should see the crystal sockets.
http://radiopics.com/RS-Realistic/PRO-16A.htm
Bill B.
Oct 14, 2010 | Radio Shack Radio Communications
How do i program my realistic pro-2025 scanner
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the
scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows
up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency
appears on the display one digit at a time.
7. To program more channels repeat steps 3-4.
Jun 03, 2009 | Radio Communications
SCANNER
Hello bigianne, You did not list the model #'s of the scanners and my telapathic powers are not working right today. For the uniden scanner go here and download your manual for your correct scanner #. http://www.uniden.com/index/manuals_results.cfm?cat=3
For the realistic scanner, that is Radio Shack, go here and do the same,,
http://support.radioshack.com/support_electronics/2849.htm
Hope this helps you out, and be sure to let me know,,, Mechanic
Oct 23, 2008 | Uniden Radio Communications
Realistic pro 2010 scanner
to program
turn on unit, press program button, key in frequency ###.### press enter. keep advancing thru the channels with the program button until finished
Jun 24, 2008 | Audio Players & Recorders
Realistic hyperscan400 channel
cant get channel codes for my uniden hand held
Nov 13, 2007 | Uniden BC60XLT Handheld Scanner
Realistic pro-54 scanning reciver
this unit requires crystals for each freq.
Oct 21, 2007 | Radio Communications
73 people viewed this question
k24674
