Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Press the power button, the bios will boot, you will see the ACER logo on the screen, then the screen will go blank, and will not show any hard drive activity. I went into bios, it can see both hard drives and CD rom. I reset the bios back to default. Rebooted and I got the same, acer logo, black screen and nothing. I checked the power from the Antec power supply that I installed a year ago with a tester and it had a LL on leg 12v2. I got another new Antec power suppply from Best buy on Sunday and checked it with my Antec power checker, the same thing showed up 12v2 LL. I went ahead and plugged up the new Antec power supply, and got the same results. I removed all memory and installed one stick, same results. I removed all pci cards except for the video, same results. I removed the hard drive and got an error of no os. So I think my hard dives are fine, and memory is good, is the MOBO shot?
  • jonjcapps Feb 03, 2010
    is there a way to test the motherboad? I thought of using a bootable cd room to check the pc. I do not get any boot error sounds, I did not try to boot with out memory, I wonder if the mobo gives error sounds on boot?
  • 2,567 Answers
Seems that you eliminated every possibility of failed components except for the motherboard. But before assuming that the motherboard is the real source of the problem, I would suggest that you try to run the computer using another monitor. And if possible, try to test your monitor on another computer.
Also, test the computer without any peripherals attached, like printers, scanners, ...etc.
If the computer still behave in the same way after all this, then you're 100% sure it is the motherboard.
Posted on Feb 03, 2010
  • Mohamed Omran Feb 03, 2010
    You could purchase a POST card tester like the one described here:
    http://www.pc-diagnostics.com/pc_diagnos...
    This could enable you test the motherboard, even if you don't get any beep codes from it. It has a 7-segment LED display which displays the code corresponding to the error. If you are familiar with motherboard troubleshooting & repair, you can use this code to diagnose the problem.
When turn shows logo turns off
I would remove the power supply, battery, hard drive and RAM. Power up the laptop with just the power adapter and enter bios. If it goes to bios OK, select the default setting. Press F10 and let it try to re boot.
Remove the power supply and fit the RAM. Insert the power supply and try to boot. You should have error message on screen. Remove the power and insert the hard drive. Connect the power supply and attempt to boot.
That sequence should show the issue at the point that there is no display that is where the issue is,
Dec 13, 2013 | Dell Inspiron Computers & Internet
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
My Acer ASPIRE 4736Z laptop is booting up, but after the Acer logo, it only shows blank screen and a blinking cursor. I've tried every solution that I've read from here and other forums, but they didn't...
Based on your explanation, it seems you have a hard drive failure.
Quick solution:
1. You can use Live CD (Hiren, Ubuntu and etc) and boot via USB pen drive to check your hard drive problems.
2. You can use recovery DVD given by your seller.
Hope these will solve your problems.
Aug 28, 2017 | Acer Aspire One PC Notebook
I want to reset my bios aspire 4730z.. please help me... i want to downgrade my laptop from win7 to xp...when i refomat to xp blue screen appear and some saying error.. please help
  1. Press the F2 key to enter BIOS Setup during Power-On Self-Test (POST while the Acer logo is being displayed). You can set the bios to default if needed.
  2. Using the keyboard arrow keys, arrow over to Boot.
  3. Refer to on screen instructions to set the first device to CDROM.
  4. Press the CD-ROM drive eject button and insert the System CD.
  5. Close the CD-ROM tray.
  6. Press the F10 key, and then the Enter key to save the changes and reboot the system.
  7. The computer will boot from the installation disk, follow the prompts to press any key to boot from cd.
  8. When you get to the screen that shows the partitions you should delete all of them, and then create new one. format and install your os. I hope this helps you good luck
Sep 24, 2010 | Acer Aspire 4730-4947 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Does boot up
If you are getting the underscore in the upper left corner of the screen the laptop is not froze, however it cannot find an OS (Operating system- aka windows) This leaves us with 2 possible options:
1. Your system (Bios) has changed boot priority
  • Depending on your computer you may get a prompt to press a key to change the boot order, if this is the case make sure your C: drive is selected, or Hard disk drive as it is a laptop you should only have one.
  • If you do not get a prompt for a boot priority screen you will have to enter the BIOS or system setup, this is ussaly done by pressing "Delete" or "F2" when you first boot up you will see the screen and it will tell you what key to press. Go into the bios and look for the boot priority settings and make sure your hard drive is at the top of your list
2. Your computer's hard drive has been corrupted and you may have to reinstall the OS.
Jan 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Help to repair ACER Travelmate 290LCi
this is normally motherboard or powe side problem check your motherboard
Oct 19, 2007 | Acer TravelMate 290LCi Notebook
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
