Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
New gas dryer
My new gas dryer smells like burning plastic. t was just delivered today and we took it out of the box. it is heating up but it really stinks
    President:
  • Whirlpool Master
  • 2,651 Answers
Good vent??? remove bottom coverif available, make sure nothing hitting againt gas flue, a little smell probly normal, figure that machine has never been heated up beforeshould go away with in a few cyclesof heat. if not call for service!
Posted on Feb 23, 2008
I have a ready heater pro 100 and it fills the room/garage with a gas that burns the eyes and really stinks??? It is propane???
Could be escaping gas. Gas providers usually ensure the gas they supply smells bad so leaks are difficult to ignore. I have never experienced stinging eyes from the gas though.
Stinging eyes and possibly a dry and scratchy throat sound more like a heater that is burning inefficiently and producing excessive amounts of soot and carbon monoxide and probably other foul and potentially dangerous substances in addition.
All heaters produce such gases and should not be used without ventilation but when a heater is in a good state of repair and burning efficiently the emissions and the ventilation required are minimal.
From your description it would seem something about your heater is faulty and you should not be using it until it has been checked and declared fit to be used, when you should find it no longer stinks or makes your eyes sting.
One thought, if you have a dog about the place that has spent all summer marking his territory on your heater, it will stink, really stink, and make your eyes sting for a considerable time...
Feb 20, 2015 | Heating & Cooling
Burning smell from heater when on high & fan on low
burning antifeeze, do you do 2 years AF service, or wait for the core
to rot thru.???
when the AF, gets old it goes Acidic. this eats the core,(heater) and
then it drips, and stinks.
or something died in there, (mouse)
or is the fungus growing.... sucked in from A/C evap. side? >???
or some chuck of sealant in the heater box hit the core and stinks
at 180F temp.
for sure it real,, you nose , KNOWS.
Feb 10, 2014 | 2003 Jeep Liberty
Wat gas has a burning smell?
You might have some dust or something in the vent tube. CLEAN IT NOW, it could cause a fire if lint is in it. Washington Gas Co. as well as others had to put an atitive in there gas to make it smell to know you have a leak. Natuaral gas on its own has no oder. Propain Stinks. If you smell what you think is gas, have it checked NOW.
Nov 07, 2011 | Dryers
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
My new Electrolux IQ 8.0 cuft dryer smells like burning oil or grease when you run it. I just got it yesterday and have run 4 loads. It still stinks. My husband thinks this is normal. Is it?
From http://tedmalone.blogspot.com/2009/06/dryer-problem-solved.html
It turns out that the inlet vent in most dryers is louvered to mix in some outside air with the air being heated by the gas (~ 500 degrees F). In an effort to be more efficient, Electrolux removed these louvers and have not been able to lower the heat enough in their gas dryers to keep from burning clothes. Furthermore, it turns out there is a *new part* which if you're in-the-know you can order. It is the same part, but with the louvers back.
Jan 23, 2010 | Electrolux Dryers
Dryer is heating but smells like something is burning. Clothes stink
HI,
i stronlgy suggest you that dont use it if you are smelling a un usual scent like burning wires.
to prevent any accidental that may occur.
bring your dryer or call a service technician to check parts by parts maybe some are only short circuited.
thanks,
May 28, 2009 | Dryers
Dryer gives off a strong odor which make my clothes smell.
if you have been painting or staining recentley the chemicals in these products are mixing with the mercaptin in the gas to cause the odour. The problem will correct itself when the fumes are gone.
Nov 11, 2008 | Maytag MDG2706A Gas Dryer
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
