Question about Canon EOS Rebel XSi Digital Camera
Hi, I see the pictures I took with my Canon XSi but when I put the memory card in the computer (Dell) the pictures don't appear and when i return the card to the camara it says it needs to be formatted. Any clues?
    Brigadier General:
  • 11,967 Answers
Yes...when you pulled out your card from the computer, you didn't use the "safely remove hardware" icon at the bottom right of your screen. Now your camera doesn't recognize the card and wants you to format it. If you do, it will be completely erased. Get yourself a separate card reader and use it to download your pics. When you plug it in, if it doesn't appear on the screen, open, "my computer"...it will be listed as a removable drive. That's probably where they were in the first place when you couldn't find them.
Posted on Feb 03, 2010
Canon XSi download busy
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 11, 2012 | Canon EOS Rebel XSi Digital Camera
I czn not down load the pictures on my rebel xsi camera to my computee
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 14, 2011 | Canon EOS Rebel XSi Digital Camera
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
I have a canon XSI camera. i have the following problem. After i took some pictures ,i took off the sd memory card from the camera to see the pictures in the pc.I saw the pictures wihtout problems and when...
Yes, you are correct. Many people think that the little slider on the memory card is a switch that does something inside the card. In fact, the slider is just that... a tiny plastic slide and nothing else. There is indeed a microswitch inside the camera, and it is necessary that the plastic slide operates this microswitch (which it should do in the 'unlocked' position) for writing to the card to be enabled. If the microswitch is not operated, the camera gives 'card locked' error.
Try a different card. If you find one that works, perhaps the tolerances are out of spec. If no card works, perhaps the microswitch is actually broken.
Jan 20, 2011 | Canon EOS Rebel XSi Digital Camera
My computer won't recognyze my canon xsi. I plugged it in with 2 different usb cables, didn't work. I put in the memory card, didn't appear in my desktop. I re-installed all the applications, but the EOS...
Jan 18, 2011 | Canon EOS Rebel XSi Digital Camera
I took the CF card out of my Rebel XTi EOS camera to look at the pictures on my computer. When I put the CF card back in the camera I am getting the message "There is a problem with the CF card. ...
This is an old posting but I'd like to comment that once the memory card is used in a computer it won't read in the camera again until you format the memory card. Make sure you have all your pictures on the computer before formatting the memory card. A memory card must be formatted in the camera it is going to be used in.
Jan 01, 2011 | Canon EOS Rebel XSi Digital Camera
The disks that came with my Rebel won't play on my mac, it's version 10.5.5....any ideas why? Thanks
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use iPhoto or any other photo cataloging program.
Oct 06, 2010 | Canon EOS Rebel XSi Digital Camera
Computer don't recognize the Canon EOS XSi
Jul 21, 2009 | Canon EOS Rebel XSi Digital Camera
Memory card will not show up on my computer.
Verbatim compact flash card has over 200 photos corrupted files. I volunteered to take photos for local senior anniversary I was the main camera now, I have lost the content. Files are Dcim--JPO, POG and worse coded files not JPEGs and I even with trial acdsee repair I am unable to rename and restore these photo files. CVS photo was able to open some of the files with their program but advised we would need to find the proper recovery program to restore some of the files.HELP
Jul 20, 2009 | PNY 4GB Secure Digital High Capacity...
Canon EOS Rebel XSi Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
