Question about Linksys Wireless-G WRT54GS Router (e125894)
Updated Canadian firmware
Trying to find updated Canadian firmware for this router. Since I have a WRT54GS-CA the US update doesn't seem right. The Canadian site is useless for this. Router keeps dropping off line without cause so I'm hoping an update might fix that.
  • kayne1 Feb 21, 2008
    Thanks. I did solve the prob when I got to the correct Canadian site. which is www.ca.linksys.com/.....The incorrect one is www.linksys.ca which has only links to commercial sites.
  • 3 Answers
Check the exact model of your router with the version number.. it can be found underneath the device itself.. you could also check the firmware on the router's page by accessing it, then go to the status tab.. on that kind of routers, if the firmware ranges from 1.50.0-1.51.2 you need to upgrade that because it gives you a problem.. the latest version is 1.52.2.. those are routers of version 5 and 6.. you can download the firmware at www.linksys.com/downloads.. select NA and usa first then type your model number and select your version number.
Posted on Feb 21, 2008
Configuration Lost After Restart
there must be some memory on the board that isn't functioning properly. Try to do a factory defaults and set it up and see if it sticks. If it doesn't then I would suspect bad circuitry or perhaps firmware issue. You can upgrade your firmware may resolve this issue.
Here is where you can download your manual and download firmware. Do not update firmware through wireless connection!
http://www.dlink.ca/products/?pid=DIR-601&tab=3
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
The updated version of firmware is level 1.02NA You can check which level of firmware you currently have installed and if its a lower number you can try to update it if factory defaults don't do the trick.
May 19, 2012 | D-Link Wireless N 150 Home Router 4Port...
I updated the firmware on a linksys WRT54GS router and turned it into a brick. I've tried to reset with reset button with no success. What can I do? I cannot see the router at all.
you should back up firt the data before updating any firmway.... go to lynksys website support and download the original firmware version.
Jun 01, 2011 | Linksys Wireless-G Broadband Router
My wireless portion of my router has not been working, and a reset has not helped. I was told by an on-line help section that my firmware may need to be updated.
If you can still access the router setup page, yes doing a firmware upgrade will be a good thing to do here to correct the wireless problem, to download the firmware you can go to linksys.com and just select your routers model and proceed with the download and with the update....
Nov 01, 2009 | Linksys Wireless-G WRT54GS Router...
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
Playstation 3 disconnecting from wireless gaming
Linksys loves to ship their routers with out-dated firmware. If you haven't updated the firmware of your router, that would be the first thing I'd do. From what I've read about routers and PS3, a lot of routers had trouble when they came out but had firmware updates to resolve the problem.
You'll need to go to the below link and select your version to get firmware downloads specific to your Model router and version number. The version number is listed on the bottom of your router next to the model.
http://www.linksysbycisco.com/US/en/support/WRT54GS/download
Be sure to read up on how to update the firmware and be sure you only update the firmware from a computer connected via WIRED connection to the router. Doing it wirelessly will cause disconnection from the router mid update and will cause your router to become a paper-weight!
http://www.linksysbycisco.com/static/us/Learning-Center/
The above link is a good website to find out a lot of information about Linksys routers and how to secure/update/configure them.
Mar 04, 2009 | Linksys Wireless-G WRT54G Router
My cell phone won't connect to my router with out help.
You need to download the firmware from linksys.com/download then save on your computer.
To update the firmware, here's the step
1. Open Internet Explorer, type http://192.168.0.1
2. It will prompt your for username and password. Type admin on both.
3. When you get to the router's Setup Page, go to Administration, then click the sub-tab Firmware Upgrade.
4. Browse for the firmware that you downloaded and hit Upgrade button.
5. When its done, power cycle the router. Just unplug it for 10 sec and replug it.
It should be updated now.
Jan 14, 2009 | Linksys Wireless-G WRT54GS Router...
Firmware will not update
Next time install http://www.dd-wrt.com/dd-wrtv3/index.php
Jul 04, 2008 | Linksys Wireless-G WRT54GS Router...
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Installed but says that router is not supported....model no.wrt54gs...what can i do now
check the manufacturers website for an updated firmware upgrade for your router & or driver.
good luck
Terry
Mar 30, 2008 | Computers & Internet
WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Jan 12, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
87 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
