Question about PPI PCX-2200 Car Audio Amplifier
My ppi 2200 power light flash's on and off - PPI PCX-2200 Car Audio Amplifier
  • 1,068 Answers
Yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Posted on Feb 04, 2010
I HAVE A PPI PCX 2200 THAT IS NOT GETTING ANY POWER AT ALL I CHECKED ALL FUSES STILL NO POWER
1.verify connections...Make sure your ground wire is grounded to a location on the body where you will sand the paint away to make good metal to metal contact. 2.with a volt meter check for battery voltage on the red wire of the amp as close to the amp as possible.verify that your remote or trigger wire from the radio (blue wire) id connected to the remote terminal of the amp.. turn on key switch, turn on radio and see if amp powers up. if no then verify 12 vdc at the remote terminal of amp, very 12vdc at red power wire. verify ground. If all this is good i would suspect you have a faulty amp.
May 05, 2011 | PPI PCX-480 Car Audio Amplifier
All lights flash simultaneously.
Turn off power. Wait 10 seconds. Turn power on.
There should be no flashing lights.
Feb 08, 2011 | Epson Stylus 2200 InkJet Photo Printer
I got a laptop Dell Inspiron 2200...I turn the power on and all the four (4) green lights goes on then flashes a bit a wont turn on... ANY CAN HELP ME.... Thanks
If the the four lights on the computer come and then go off. Then these are the diagnostics lights telling that the motherboard has gone bad and needs a replacement
If they flash in some sequence . The the problem could be with one of the internal components.
For more information on the same you can visit www.support.dell.com
Thanks for using fixya
proton
Jul 28, 2010 | Dell Inspiron 2200 Notebook
Subs and amp sat in my garage for a year. I just
check your subs by connecting them straight from the stereo. If they work then there is an issue with the signal comming from the stereo through the rca cables to your amp, check those. Try another amp if you can with those rca's or test the amp with a friends car, either way try to rule out everything until it points to the problem.
Apr 17, 2010 | PPI PCX-2200 Car Audio Amplifier
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Amber light on front of laptop flashes even with the power off
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Amber light on front of laptop flashes.
Protect light flashing on and off, sub cuts in and out
there is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Dec 01, 2008 | PPI DCX-600.4 Car Audio Amplifier
2200 locked up
disconnect the printer from the computer - power off printer - check for obstructions / torn papers - power on
if paper light is still on/flashing and pressing it does not do anything - you got a hardware issue - call manufacturer for reccomendation
this might help also - http://www.epson.com/loyalty
Dec 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Problem in ppi pcx-2400
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Jul 15, 2007 | PPI PCX-2200 Car Audio Amplifier
PPI PCX-2200 Car Audio Amplifier Logo
109 people viewed this question
Top PPI Car Audio & Video Experts
Matthew Spark
Matthew Spark
Jose Velazquez
Jose Velazquez
Jerry Kramer
Jerry Kramer
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
