Question about Dell Inspiron 6000 Notebook
DST short status test failure
I'm having the same exact problem with my dell laptop... But I don't have the original cd's that the computer came with, they got misplaced somewhere over the years... I figured that I need to reboot my computer, but I want to be able to back up my data first so that I don't lose all my pictures, music and MS word documents. Should I purchase the cd's again, or do i just get a new hard drive? Is there anything that can be done to save all my files? Please, any advice would be helpful
thank you
    Guru:
  • 194 Answers
There is a few things you can do. You can purchase a new Windows CD from your favorite electronics store and install it. If you do that, you will have to visit the dell support site, put in your service code, and download all the drivers to install manually on your computer. If you purchase and install Windows 7, which is Microsoft's latest version of Windows, it should recognize most if not all drivers needed for your system.
In terms of backing up your system: Once you have purchased a new hard drive and loaded windows onto it, you can also purchase an external hard drive enclosure kit (one without a hard drive in it). Using this kit, you can take the hard drive out of your old system and put it into this kit. Plugging the device into the computer (after installing windows) you can then pull off all your old information.
A less expensive but not necessarily recommended short term solution would be to purchase the external hard drive enclosure kit, take the hard drive out of the system and put it into the kit, hook it up to another computer, right click on the drive in My Computer and select properties. In properties, click on tools tab, and then click "check now...". Make sure you select for it to repair any errors. This will probably (no guarantees) make your hard drive usable again, but only temporarily. Ultimately you do need to replace your hard drive.
Good Luck,
NOLA Tech
Posted on Feb 03, 2010
Short dst failed fix
Drive short test failure usually indicates what it says, which is a fault with the drive, but you state that this happened after an update (don't trust windows update!)
do you have have any error codes this could indicate further the exact problem. but usually this type of error would indicate a drive fault which would require replacing the drive
Cheers D
Mar 03, 2014 | HP Pavilion g6-2210us Notebook Laptop PC
After i push the start button. the dell screen comes up, nothing after that happen.. sop i pushed fn-power.. and it started to run a diagnostic test =-everythng passes except the "start DST short test" it...
When the DST short test fails it means you hard drive has failed. You need to get in contact with Dell and see if you can get the it repaired or replaced. You will have to pay for the repair if your computer is not under warranty or does not have the extended service plan on it.
In order to check if your warranty is still valid you can go to support.dell.com and look under Warranty Information - > Warranty Status or you can call dell technical support.
Sep 08, 2010 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST Short Status Test. Error Code 1000-0146
sounds like your hard drive my need changing
Aug 16, 2009 | Dell Latitude D610 Notebook
DST Short Status Test Failed
MY DELL NOTEBOOK IS SAYING DST CAN YOU HELP ME
Jun 26, 2009 | Dell Inspiron 9300 Notebook
Failed DST Short Test and Screwy Mouse/Keyboard
Hi there.
I'm sorry to say that error code 1000-0146 means that the hard drive is failing and it can go at anytime, get yourself a USB mouse and start the computer up, the operating system should recognize the mouse and install the drivers (it may take a couple of minutes so be patient), as soon as the mouse is installed it is imperative that you back up all of your data, either to an external drive or CD/DVD.
Then you have to purchase another dive of if you have any warranty on the laptop send it in for Dell to repair.
If you are out of warranty and need instruction on how to install a new drive please feel free to post back.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Dell Inspiron 6000 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
DST result fails
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Feb 05, 2009 | Dell Latitude D610 Notebook PC
Dell Inspiron 6000
The short DST test is generally the failure of the HDD,It would giive you code next to it , that would something like 1000-0146,or 1000-0141 etc. Do give that code and I would let you know the exact failure
Thanks
mandeep
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
325 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
