HP Pavillion N3350 All White Screen Problem
Hello! I recently inherited an HP Pavillion N3350 from my brother that has a problem with the LCD. The screen is all white all the time and doesn't display anything at all. I plugged a monitor into the port in the back and it worked fine. I've checked for loose connections on the MB, and both of the connections on the inverter board without results. It isn't a harsh white screen with the heat I've read about; it is more of a soft, unhelpful, white screen. Any idea as to if it would be an easy/cheap fix?
  • juan geezy Jan 09, 2009
    white screen when i hook up other screen works fine
    Scholar:
  • 181 Answers
Sounds like the lcd itself, or the ribbon cable needs to be replaced.
I'd try that first.
Good luck
Posted on Feb 20, 2008
White screen start up
You LCD display panel or display cable needs replacement if it progressively turns white when you boot up.
Feb 03, 2014 | HP Pavillion ZV6000 Notebook
Hp pavillion screen on laptop is a white out
Have you dismantled this recently? If so, check that the video cable from the screen to the motherboard is firmly in its socket.
If you have not, then try to connect it to an external monitor and see if the problem goes away, that will eliminate the graphics chip if it does. You then need to look at the screen itself, checking all connections are tight. Normally with a white screen, the backlight is working and I would think the inverter is too (although not definate), and it would apppear to be the connection between the mobo and screen.
If it still persists, there is a much deeper issue with the motherboard
Dec 30, 2010 | HP Computers & Internet
Please please, may I have the part number or description to locate the replacement motherboard for this pavilion n3350?
sorry i tried to look for it but couldnt find it
found this though----www,hp.com/motebooks
and (us) 970-635-100------------customer care
Sep 07, 2010 | HP Pavilion n3350 PC Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Hp webcam in built
Hello
webcam has small CCD in it and if it goes bad it will show you blue or white image sometime and then other times it will work fine is it is showing you blue or white images sometimes you can take LCD bezel of and then replace webcam easily it is just a small board with CCD inbuilt.
Thankyou
May 05, 2008 | HP Pavilion dv9000z Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
Computers & Internet Logo
768 people viewed this question
Alun Cox
David Payne
David Payne
