Printer after I turn printer on with enough paper to print the paper flasher light comes on and nothing prints; paper doesn't feed either. Could u help me this problem?
  • Anonymous Sep 21, 2008
    I haven't used this printer for a couple of years. I hooked it up to my laptop. Lights come on paper feeds and comes out with nothing on it. Ran test pages - same result nothing printed
  • Niteesh Ahire
    Niteesh Ahire May 11, 2010
    Give me your printer model & mfg detail.
  • 65 Answers
If Your printer's waranty is over open your printer's cover & clean it clearly all dust. Then you should install it again & Try again
Posted on Feb 25, 2008
    Genius:
  • 3,587 Answers
Run a test print page, please..and report.
Posted on Feb 20, 2008
My Star TSP600 Thermal Printer is displaying a flashing Error light. Power light on, new roll of paper loaded correctly, self-test was ineffective - nothing printed. What's my next step?
i know you stated you put the paper in correctlyin the printer but if the thermal reactive side of the paper is not facing the print head the thermal paper won't print on the wrong side of the paper. it will load into the printer and seem ok but the heat on the wrong side of the paper will not react and show any writing. Can you try turning the paper over in the printer feed holder so the other side of the paper faces the print head and give it another test .
Jun 21, 2016 | Star Micronics TSP600 Thermal Printer
My printer has the blue light on the lightbult and low toner (but ink is fine) - it will not print anything. The stuff sits in the print queue and i have to eventually delete it. The report will print...
My work-around for this problem is to feed paper in manually through the front. I turn the printer off and make sure all paper is out of the printer. When you turn the printer on - and the blue light stays lit (if it doesn't turn it off and wait - I've had to wait quite some time sometimes).. then manually feed 1 sheet of paper in the manual feed tray at the front. When the paper is inserted... you should be fine to print - and keep feeding paper in until you get your job. If you miss - you might need to hit the "continue" (triangle button)..
I've been trying to find out why mine locks up - and why it keeps jamming - but this is a tried and proven menthod - althought it is annoying it might help you for now.. Good luck
Sep 02, 2011 | Lexmark E250dn Laser Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Why the epson stylus C86 dont print nothing?it makes noise like its print but on the paper nothing
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
You can run a printer check to determine whether a problem comes from the printer itself or some other source.
1. Make sure both the printer and computer are turned off. Then disconnect the interface cable from the printer.
2. Make sure letter-size plain paper is loaded in the printer.
3. Hold down the paper button, then press and release the power button. Continue holding down the paper button until the green power light starts to flash, then release it.
If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the ink button on the printer for three seconds. (This only works when the red ink light is off.)
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus C86 InkJet Printer
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Apr 06, 2009 | Zebra LP 2844 Thermal Printer
Paper does not feed all Malfxn lights on
Can you tell if the feed rollers are turning? Depending on what type of printer it is, you feed rollers could be worn and not picking up the paper.
Feb 27, 2009 | HP LaserJet 5p Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Printer Won't Take Paper
I beleive that machine has two slots to put paper, try moving the tray to the other slot, for some reason it may have defaulted to that tray.
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
Paper Feed
Try turning the printer upside down and shaking it. Sometimes something small like a paper clip or Lego brick gets down inside and will prevent the paper from feeding.
Apr 04, 2007 | Lexmark X75 All-In-One InkJet Printer
184 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
