Question about Kenwood CD-403 5-Disc CD Changer
HELLO, I HAVE A KENWOOD CD PLAYER, 403 DPF-R SERIES. THERE IS NO REMOTE CONTROL WITH THIS UNIT, NO VOLUME CONTROL ON THE FRONT, NOT ALLOWING ME TO GO STREIGHT FROM THE UNIT TO SPEAKERS. WHAT REMOTE CONTROL ( IF ANY ). WILL WORK FOR THIS UNIT? E-MAIL CMCKINNEY1951@ATT.NET
    Brigadier General:
  • 8,546 Answers
CD players need amplifiers if you want to listen to them over speakers. Nothing to do with a remote.
Posted on Feb 03, 2010
Can someone please tell me what color wire on the back of the head unit is the REM wire? It's a Kenwood Excelon X559 series. thanks
Amplifier remote turn on is blue/white, power antenna remote turn on is blue. The power antenna remote turn on turns off when leaving tuner mode.
May 12, 2011 | Kenwood eXcelon KDC-X559 CD Player
Remote Control of Unit has ceased, tried the original as well as others. Otherwise the unit functions ok from the Front Buttons on the Player
Sounds to me like there's a fault in the remote censor of the CD player. You could have a look around inside following the point where the machine's picks up the signal from the remote. Otherwise it's off to the repair man.
Apr 08, 2010 | Kenwood CD-423M 200-Disc CD Player
Rear Speakers
Hello kaykayscott1,
Here's a link to the manual.
First make sure that the green green/black and purple purple/black pairs of wires are properly connected to operate the rear speakers.
You can check and adjust the "fader" and "rear volume" settings from the front panel. Go into settings by pressing the CONTROL knob. Then press CONTROL repeatedly until you get to the setting you want to check or adjust. When the display reads "R-VOLUME", turn the CONTROL knob from 0-35. Press CONTROL repeatedly again until the display reads "FADER" and turn the CONTROL knob from Rear 15 - Front 15 until you get the setting you want. Exit audio control by pressing any button.
Hope this helps.
Jul 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood ddx512
The unlock code usually only goes on if you previously put one on there. I would suggest calling Kenwood but there is a guy that claims he can fix this i have never tried this but you can. http://mike-unlockcodes.blogspot.com/
Apr 24, 2009 | Kenwood DDX-512 Car DVD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Compatible units
Hi check if your changer connects to the amplifier with a single ribbon cable. if this is the case then the unit is not compatible with anything else.
If it has its own mains cable and a couple of RCA connectors on the rear, then anything should be fine
Jan 02, 2009 | Kenwood CD-404 5-Disc CD Changer
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
Kenwood MP4029 4 code reset
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Sony CDXM 8800 Xplod Car CD player won't repond when buttons are pressed
There is a reset button on the area behind the faceplate. You will have to go back in and redo many settings but just hold the tiny button down with a ballpoint pen for 15-30 seconds and it should reset allowing the faceplate buttons to operate.
Mar 01, 2017 | Car Audio & Video
Kenwood CD-403 5-Disc CD Changer Logo
150 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
