Question about BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal
Ive got a delay ,chorus , wah ,distotion and compressor . how would i aet them in which order . thanks
  • 4,234 Answers
Generally speaking, other than having hte compressor first to provide a consistant level to the other pedals, the order is personal preference. You need to experiment and determine the types of sounds you want. There is no "standard" order.
Dan
Posted on Feb 03, 2010
Which is the best chorus pedal for a guitar?
According to me and many professional guitarists, the best chorus pedal is "MXR M234 Analog Chorus Guitar Effects Pedal"
It is durable and easy to use.
Some of its best points are:
? Volume is consistent
? Affordable price range
? Versatile tone and effect
You can check many other effects pedal at this link:
Best Chorus Pedal Top 5 Best Chorus Pedals for Your Guitar 2017
Feb 22, 2017 | The Music
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
I need parts for my 2002 clyde deluxe wah.....one knob for the side 3 tone mode and 2 feet with screws....can you help thanks Wayne 443-850-5240.....
You can get the feet at home depot in the hardware section. They should be in the specialty drawers.
you may be able get the knob there also. if not, Radioshack has a small selection of replacement knobs. Do you need the 3-way switch also?
Sep 13, 2011 | Fulltone Clyde Deluxe Wah Pedal Wah-wah...
I have a problem with my roland jw50 keyboard,,, i dont really know the cause ,,, any key i press makes only a single tone and it is distorted.. thank you..
Check the setting for your envelope ,attack, decay, and release
Check Effects settngs reverb/delay chorus/flanger
you probably have one or a couple of these setting way off
May 16, 2011 | Music
Hi there, i got a 5150 half stack amp and the evh wah pedal, my problem is when i engage the pedal comes a terrible hum, i already change the cables, 9v battery and the ac adapter and the big noise...
WHY are you using a battery AND a 9 Volt adapter? This is an either/or thing. Chances are you have a defective ground someplace. Use just the battery and try it... If the hum is gone, the adapter is NOT compatible with the pedal. A lot of hum problems occur because the guitar is near a source of magnetic fields, such as an amp. An embarassing thing is for a musician to reverse the in and out connections to the pedal... it will have the symptoms you have mentioned.
Apr 24, 2011 | Dunlop EVH Wah Wah Pedal Wah
I just bought a Deluxe VM .... when I plug it in, the red delay light is on....and everything has delay on it. When I press the little white button on the amp in or out, the red light on the amp still...
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Feb 25, 2011 | Fender Deluxe VM Tube Amplifier
Basically i cannot seem to make the pedal work in tandem with my crate flexwave 120w 2x12 dsp amp i prefer to use the built in dis,chorus, and delay effects but can find no way to put the hb01 behind the...
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
http://www.crateamps.com/pdf/manuals/FW120H_OM.pdf
Jan 11, 2011 | Behringer HB01 Hellbabe Wah Pedal
When playing it has a roaring sound and the chorus on and off is loss
Who could even guess what musical instrument you are talking about...
BUT I will say that if it is a device with a chorus setting that uses CCD (charge coupled device delay line), there COULD be a problem with the device. This would be a job for a service shop for the unit.
Jan 15, 2010 | Music
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal Logo
107 people viewed this question
Top BOSS AUDIO SYSTEMS Music Experts
Vito Vacirca Jr.
Are you a BOSS AUDIO SYSTEMS Music Expert? Answer questions, earn points and help others
