Question about Amana ATB1832AR Top Freezer Refrigerator
The freezer temp is zero max, it won't go colder,
The freezer temp is zero degrees C max, it won't go colder, everything else appears to be working fine.
    President:
  • 2,468 Answers
Remove the cover to the evaporator in the freezer compartment and see if the evaporator coil if partially covered with ice build-up, if so defrost it,clean the evaporator and condenser coils of dirt and dust and try it again,also make sure the door seal in both compartments is good and not leaking warm air into compartments,as this will condense and make ice build-up,if this happens again after these ideas,then check and make sure the defrost system is functioning properly
Posted on Feb 03, 2010
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
After power interruption we find the temp is sitting at 48 degrees fridge side and 19 degrees on the freezer side.
After about 24 hours your temps should be close to zero in freezer and about 37 in refrigerator. If not check position of thermostat control and turn clockwise for colder temps if necessary.
Mar 16, 2016 | GE PSC23SGRSS Side by Side Refrigerator
Water not freezing in freezer freezer temp button was played with
Adjust the temperature control for colder temps - usually clockwise. When operating properly temp should be around zero degrees.
Aug 30, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
My sub-zero 642 will not get colder in the freezer than about 9 degrees and the fridge won't get colder than about 45 degrees. I turned off the breaker and vacuumed the coils, but still no change. ...
The Sub Zero 642 uses independent refrigeration meaning the freezer and refrigerator each has their own system. Best to have an "Authorized Factory Service Company" check it out.
Jun 08, 2011 | Refrigerators
Looking for ideal freezer temp
For most freezer sections of a refrigerator, zero degrees F is ideal. -2 to +5 range is acceptable, but the warmer temps will reduce icemaker productivity, while colder temps might make that ice cream as hard as bedrock.
Apr 02, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have a haier deep freeze model hcm050ec what is the pressure suppost to be
I am assuming you have some refrigeration smarts. As a general rule the evap in a freezer is 10 degrees low than the box temp. Take the pressure of the low side then look on a P/T chart for that refrigerant and determine if it is where it needs to be. Usually somewhere around -10 to-15 degrees for a zero or colder box.
Sep 25, 2009 | Freezers
Sub-Zero 650/F
get into diagnostic mode by pressing and holding either colder key, then pressing on/off. You can use the colder key to scroll through 5 reading labeled fe, re, f, and r  look at the re temp. is it higher than 38? if it is you probably have a freon leak in the evaporater refridgerator (call sub zero...they will completely pay for this issue, even past the 5 year warranty)  If the temp reads really low (like 10 on re or something) you probably have a bad fan or fan switch in the fridge portion. this unit has seperate compressors and freon for the fridge and freezer..hence the lack of problems in the freezer. hope this helps!
Oct 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
Amana ATB1832AR Top Freezer Refrigerator Logo
35 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
