Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Whar does f1 error mean - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
The flood switch at the base of the dishwasher cabinet has activated. This occurs if moisture has leaked into the base of the dishwasher.
There are several posts on the fixya.com site on causes and solutions.
If unable to find please post a comment and I am happy to guide you on this.
Posted on Feb 04, 2010
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
What is the error mean f1 E1 on my may tag front loader washing machine
Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
have E1 and F1 error code fleshing and wate Sears PartsDirect
http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
Appliance Repair Forums
Error code F1E1 null ShopYourWay
Central Control Unit CCU Maytag MHW6000XW Washer
Mar 07, 2016 | Washing Machines
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Stove error f1 kenmore elite model 790.75902990
Aug 12, 2011 | Kitchen Ranges
What is an F1-8 Error?
Hello there
First your f-1 error code
The F1 Error On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
And the 8 error is also conclusive along with the f-1 meaning that the erc or electronic range controle is faulty and should be replaced
Oct 12, 2010 | Maytag MER6772 Gemini Electric Kitchen...
What does F1 mean for a whirlpool cabrio
F1 error code is for main board failure, replace main board
Sep 07, 2010 | Washing Machines
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
What does F1 fault code mean?
Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Jan 08, 2010 | Kitchen Ranges
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
104 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
