Question about Skull Candy Lowrider Headphones
I get sound only from one side i think the plug is broken can i repair this by myself
  • Skull Candy Master
  • 5,484 Answers
If you are good with a soldering iron yes is the answer.
Make certain it is the jack plug first, by moving the cable around at various points.
Here's what to do, buy a stereo headphone jack plug, gold type are best. Cut the old plug off. On the new plug you will see two small terminals and a long metal one with two flanges on the end. Strip the cable just enough, so that the thickest part just sits where the two flanges are. The striped cable will have two coloured wires (the R & L channels) and some earth wires. The plastic barrel of the plug should be put on the cable before you attach the wires. The left and right wires go on the two smaller terminals, you will have to work out which one is which, by testing the sound. It won't hurt the speakers or your amp if you get them wrong way round, just reverse them. The earths all go on the long shaft. When you have soldered them on, bend the two flanges together so it grips the cable.
PS don't short terminals with either of the channels or the earths.
If you think they might short (touch) insulate them, say with tape. Then put the barrel cover over the end. If the sound is spaced out the earths are not connected good.
If it is not the plug but the wire further up, cut it at that point and fit the plug there. You can get an extension lead for headphones to solve the short cable problem.
Posted on Feb 03, 2010
My cb wont pick up anything.
The coax on the lil will may be bad. Do you have a swr meter? If not get one and make shure its not the lil will. If you need work done www.herzjoe3@gmail.com. I have 15 yrs in cb's
Jun 24, 2012 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I have a crate gx140c guitar amp. When I plug in my guitar there seems to be a Problom with the the input and I get no sound. Is this something I can repair myself or must I take it to a technition?
If the socket you plug into is loose, there is likely a broken wire or a broken solder joint or board. It is not beyond the abilities of those who have some mechanical ability. Just have some patience, do not force anything, and if you have a doubt how things might go back together- take lots of pictures that show details and placements.
Jun 10, 2012 | Music
LIGHTING
sounds like the wiring plug has come apart at the back somewhere ,no idea exactly where the connection plug is as aim a europeon mechanic but look on the back of the light cluster and check that out first then work back ,is the name called pig tails in american slang? i think it is myself
Mar 28, 2012 | 1997 Cadillac DeVille
My kodak M1063 fell while the lens barrel was out,i tried putting it off so that it will go in but it didnt move.So decided to push it in myself thinking it will come out when i put it on.Now,the lens...
Hi, Unfortunately it sounds like the camera is beyond repair. When a camera's dropped like that there's a 50/50 chance that a mechanism in the lens has been broken and it's repairable. From the sounds of yours though, the fact that it won't come back out when you turn the camera on, it sounds like you're better off getting a new camera.
May 12, 2011 | Kodak EASYSHARE M1063 Digital Camera
I dropped my camera, with lens attached, and although the body works fine, the lens will not focus. Take the lens off the camera, and look into the back of it (the lens), and there is a round, black,...
Wow I appreciate your spirit but this is probably a loosing battle. Even if there was a repair manual you would still need the tools. This is a $150.00 - $200.00 lens. I'd probably elect to buy a new one and sell the broken one on EBAY for parts or try to take it apart just to satisfy my curiosity. Sounds like you like adventure.
Good Luck!
Feb 24, 2011 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Acer 1912 stays dark
By that description sounds it sounds like you need a new monitor. Otherwise I would say if it was just a black screen to reset your CMOS by removing the side panel of your computer, locate the round battery and near the battery is a 3 pin 1 jumper setup most likely jumper on 1,2 but can be 2,3. Which ever the case, unplug the power cord, remove the jump from 1,2 and move it to 2,3 or vice versa remove from 2,3 and move to 2,1 for 1 minute then remove and replace in default position. Plug the power back and and start it up. As I said, wouldn't go through the trouble because your monitor sounds broken.
Aug 02, 2010 | Acer AL1912 19" LCD Monitor
Kenmore SR1087 Freezer Door will not close without lifting
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
check this site out. I have the same problem but I don't have to lift the door to close yet....
Jul 08, 2008 | Kenmore 44109 / 44102 Side by Side...
GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Jan 08, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Skull Candy Lowrider Headphones Logo
335 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Joe Lamb
Joe Lamb
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
