Question about Sharp AL2030CS Black and White Copier
I have a H2 error on my AL 2030--no number pad), what can I do?
    New Friend:
  • 28 Answers
Enter:
[#] key → [*] key → [C] key → [*] key
then enter
14 (with the copy +/- keys)
then press
Start/Copy key
Posted on Feb 08, 2010
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
Sharp al-2030 h4-00 code
H is a heater problem H4 is more specific, not sure but it could be the lamp, thermistor or triac. It will be one of these or even a bad connector on the heater section
Aug 28, 2014 | Sharp AL-2030 All-In-One Laser Printer
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Jan 15, 2013 | Office Equipment & Supplies
ERROR SIST. [H2-00]
how do i clear
h2-00 on AL- 1566
Jul 10, 2012 | Sharp AL-1655CS Copier
Code error H2
h2 means the open the termistor.
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 03, 2012 | Sharp SF-2025/2030 Copier Toner Black...
I have error H 2, what to do?
This error indicates: H2-0 Fusing unit temperature error
Unless you are technically capable, you will want to have a qualified technician diagnose and repair.
If you want to try and diagnose it yourself, follow these directions.
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
Feb 03, 2010 | Sharp AL-2030 All-In-One Laser Printer
Al1631 sharp copier
This is called error code which you must specify.For H2,H3,H4, use command 14, for U2 use comm 16.Please specify if neither of this displays.
Oct 02, 2009 | Sharp AL 1631 Copier
SHARP AL-1644
To enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Jul 28, 2009 | Sharp AL 1631 Copier
Sharp AL 800 won't copy. Blinking letter and number H 2
H4-0 The fusing unit doesn't heat up.
Also check thermal fuse, if defective replace.
Jan 25, 2009 | Sharp AL 800 Copier
Sharp AL2030CS Black and White Copier Logo
88 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
