Question about Samsung Dishwashers
How to fix error code E4 on Brada dishwasher - Samsung Dishwashers
SOURCE: powerpoint dishwasher E4 error code
The solution below applies to a Powerpoint dishwasher but is probably a generic one for E4 problems - given that brandnames are frequently badges of convenience for made-in-china products.
The problems cause and solution goes as follows:
Problem:
Any water that leaks (for whatever reason) from the internals of the machine finds it's way down to the lowest point of the machine - down under the washzone and into the area where all the workings of the machine are located. There's a sensor there (a polystyrene float operated switch in fact) that detects this water - causing the machine to empty and go into error 4 (E4).
The solution will depend on the nature of the leak. If it's due to one of the various seals on the floor of the washer leaking or there is some problem with water level controls then that will have to be repaired first - otherwise you'll keep on getting the error. In my case however, the "leak" was actually a design feature of the machine and is easily rectified.
Open the dishwasher door fully and look at the floor of the machine where it meets the bottom of the door. You'll see a couple of plastic tubes protruding from the floor by about 12mm - one to the left and one to the right. Their function appears to be to act as an overflow if the water level in the machine gets too high (for whatever reason). This excess water is directed down these tubes and into the bottom of the machine where it can be detected - rather than letting it spill out onto your expensive floor. The weakness in this system is that it only takes a soup spoon of water to produce the error - something which might accidently happen during the course of a normal wash.
Options:
1) Leave the machine idle for a few days until the water evaporates. The sensor switch will reset and the error will be gone when you switch on.
For either of the following solutions, turn off the power to the machine by unplugging it or tripping the relevant switch at your fuse board
The stainless steel washcabinet is only slightly thicker than aluminium kitchen foil. Handle the machine gently and never force it otherwise you're in danger of distorting the cabinet.
2) Tilt the machine right the way forward so that the water leaves the area of the sensor. It'll flow back again once you level the machine but in wetting the floor area of the machine, the level at the sensor will be a little lower than before - permitting the sensor to reset. Switch on and the problem should be gone.
3) Pull the machine out from the built in unit to gain access to the right hand panel. Remove it (just a lot of philips screws holding it on) and you can just about see the polystyrene float (near the front) and the slightly depressed area underneath it - in which the water accumulates. You can poke a stick in with some tissue taped to it to mop up the water. Be careful not to disturb or damage the float.
note:
I've had this problem occur twice in as many years. If it keeps on occurring then you likely have a genuine problem with water level controls during filling or a leaking internal seal dripping water into the bottom of the machine.
Don't be tempted to block the overflow tubes - a genuine overflow could destroy your kitchen!
Posted on Feb 21, 2009
SOURCE: E4 error on new conia dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Posted on Dec 22, 2007
  • 60 Answers
SOURCE: dishwasher is flashing error code
"E4" code relates to the overflow detector There appears to be an internal sump. Lean the machine back about 35-45 degrees to remove the excess water from the dishwasher. It might be messy so be prepared. By design the sump collects water from condensation i.e. (Cold outside machine wall, hot inside machine wall) hence condensation builds up and is suppose to and should evaporate in the right environment. Placement and installation locations play into a big part of the design.
You will notice by observation just in the centre there is a polystyrene float. This is what activates the overflow switch which throws the error code.
This probelm is simple to fix, just take off your kitchen plinth and turn off the dish washer power. then at the base of the dishwasher there are 2 plastic clip access panels, take a blunt screw driver or knive to help you ease out the plastic panel. once this is off, simple take a dish cloth out mop out the water, particularly from the left hand side as this is where the sensor is. Once dry (ish) replace the panels and switch on - DONE! its that easy
Posted on Nov 07, 2008
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
SOURCE: how to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
Posted on Apr 18, 2010
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Brada portable dishwasher EP9242AWW
The pump is blocked or not working
Apr 13, 2014 | Frigidaire Dishwashers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Feb 27, 2011 | Kenwood KDW243A Builtin Dishwasher
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Idw604 error code e4
had same problem. Tilt dishwasher to the left and drain all the water (it will come out on the side). That's E4 solved. Now turn it on, E4 should not light up. If it does, turn it on and as soon as u do this, close the door. This won't activate the Trip Switch but will automatically turn the pump on. Good luck!
Aug 02, 2009 | Belling 24 in. IDW603 Built-in Dishwasher
Brada dishwasher EF2401 - water in bottom
I just moved in to a new house with brada dishwasher, everytime I used the water leeks from the bottom, can somebody help me to fix it, or do you think I should throw it away and get a new one.
Sep 05, 2008 | Dishwashers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Apr 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
1,558 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
