Question about Singer Sewing Machines
Sewing machine locked up. Wheel won't turn. - Singer Sewing Machines
  • 25 Answers
SOURCE: sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Posted on Jun 02, 2009
  • 16 Answers
SOURCE: machine jammed while sewing - it acts like
It sounds like there is something (a thread) jammed under in the gears you would need to take the bottom off to get a better look
Posted on Jan 22, 2010
SOURCE: necchi sewing machine problem
needs to be serviced
Posted on Jul 31, 2010
ErusTownsend
  • 592 Answers
SOURCE: Sewing machine will run for a short time and then
Many units contain a power overcharge, shock or overheating shut off system. How hard and long does the unit run before it does this to you. Also does this happen on light cloth, heavy cloth or any cloth. How fast is the machine goign before this happens. What is the temperature of the room. When is the last time you had this unit oil/lubed and serviced. Also when it locks up does the entire electrical system of the unit shut down or does just the drive stop.
Posted on Jan 20, 2011
bugoy31
  • 1238 Answers
SOURCE: HI problem with Consew 199R-1A. Machine locked
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
Posted on Jun 10, 2011
Testimonial: "I oiled it and kept wiggling the flywheel until it finally released. Thanks!"
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My bother power sewing machine has lock up the wheel will not turn
Try to turn the hand wheel backwards possible thread stuck on the needle hook by the bobbin. Take the bobbin out and remove the face plate and clean machine.
Jan 31, 2015 | Sewing Machines
Machine won't sew I hear motor running something maybe loose?
Have you checked your lock on the wheel, As when you load a reel of cotton
Mar 18, 2013 | Janome 2212 Sewing Machine
Babylock serger wheel won't turn to unlock
if you bought the machine from someone then you might think about
having the machine checked or serviced to make sure everything
is alright on the inside, since it's a babylock
Jun 09, 2012 | Baby Lock Imagine
HV mega quilter hand wheel won't turn and it won't turn on
it could be the switch or motor, it would be a good idea to have the machine checked
Apr 05, 2012 | Sewing Machines
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Kenmore model # 11607090 older model, been setting up for several years, but has never been used-cannot unlock the hand wheel. we were able to wind bobbin, but wheel will not turn.
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Sep 05, 2011 | Kenmore 1667 Mechanical Sewing Machine
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
Jun 10, 2011 | Consew 199R-1A Sewing Machine
I just purchased the sew pro portable zig zag sewing machine model zz 401 and it won?t work, the pedal makes this funny sound and the machine isn?t working. What do i do? I tried everything and tried...
Maybe the drive wheel is disengaged. Some machines have you pull out the wheel on the right to wind a bobbin and yours might be pulled out. Try pushing the wheel back in to engage the machine.
Nov 09, 2009 | Steam Fast ZZ-401 Mechanical Sewing...
Sewing Machines Logo
49 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
