Noticed after I do a load of laundry there are black (grease) spots on my clothes. I found a grease spot on the bottom of tub. What could this be?
  • Anonymous Mar 30, 2014
    grease found on the bottom of the bowl seems to have come from under the adjitator
    President:
  • 2,468 Answers
Its the topseal on the transmission thats leaking,the term for this is called "back-wash" you need a new seal
Posted on Feb 03, 2010
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
Kenmore 70 grease spots
If your starting to see black grease or oil spots on your clothes after washing and it seems to happen more and more chances are the transmission seal is busted and either the whole transmission or just the seal needs replacing.
Apr 24, 2012 | Kenmore Washing Machines
Dirt and oil spots on laundry
The rear seal and the rear waher drum bearing is defective, this allows grease to get into the washer and that is what is getting on the clothes
May 11, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
I get oil/grease spots on my laundry ffrom my
You probably have a bad seal on the back of the drum, as that bearing is the only source of grease near your clothes. Good luck.
Jan 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
BROWN GREASY RESIDUE LEFT IN BOTTOM AND TOP OF TUB
could be the transmission shaft rubber seal...need to call service tech for more help thee.
Apr 07, 2009 | Frigidaire GLWS1233A Top Load Washer
Oil in the Tub getting on clthes
the oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Dec 20, 2008 | Washing Machines
Whirlpool calipso washer
If these are gray spots it may be fabric softener. Try running a few loads without and see what happens. Also check the seal around outside of inner tub bottom to make sure it still contacts tub all the way around. If it doesn't, you need to have a tech replace the nutator assembly and hte bottom plate. Based on past experience, may be better off replacing.
Nov 18, 2007 | Washing Machines
Black spots on white laundry
is the washer noisey when spinning? If so its probable that the main bearings are worn, & losing the original grease into the wash tub. At 10-14 yrs old its probably not woth fixing (assuming parts are still available)
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
