Question about Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo) Burner
My c/d dvd does not show up on my computer, was working 5 days ago
    President:
  • 1,738 Answers
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
See the “More information” section for detailed information.
This article helps you fix the problem. To have us fix this problem for you, go to the "Fix it for me" section. If you would rather fix this problem yourself, go to the "Let me fix it myself" section.
To fix this problem automatically, click the Fix this problem link. Then, click Run now button from the Automated Troubleshooting Services page and follow the steps in this wizard.
a.button { background: url(/library/images/support/KBGraphics/PUBLIC/cn/FixItButton.jpg) no-repeat 0 0; width: 139px; height: 56px; display:block; cursor:pointer; } a.button:hover { background-position: bottom right; } Fix this problem
Microsoft Automated Troubleshooting Services: Your CD or DVD drive cannot read or write media
Note This automatic fix only applies to Windows XP and to Windows Vista. If your computer is running Windows 7, go to "Windows 7" under the "Let me fix it myself" section.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
This problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted Registry entries. To use this method, you must be logged on to Windows as an administrator. If you need help verifying that you are an administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin)
To fix it yourself:
Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters.
  8. On the Edit menu, click Delete.
  9. When you are prompted to confirm the deletion, click Yes.
  10. Exit Registry Editor.
  11. Restart the computer.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Posted on Feb 03, 2010
My dvd burner wont open
on the drive there should be a small hole open up a paperclip and insert it this fill push against the cd frame and open the tray
Nov 06, 2011 | Computers & Internet
My Philips DVD burner doesn't read dvd's
For $40, buy a new CD/DVD reader/writer, and put an end to your problem.
Jul 22, 2010 | Philips SPD2513BD DVD-RAM Burner
My most recent videos will not open on my computer. It is the same memory card that showed just fine a few days ago. The previous recorded ones on the memory card still work fine on my computer. I can play...
In explorer - Under my computer/ devices - you will either have a list or details of files - the details under type will give you information of the file format - i.e videos may show as wmp, avi, etc
May 12, 2009 | JVC Everio GZ-MS100 Camcorder
Dvd disk drive not showing in my computer
Hi!
The chances are that the drivers for them got corrupted and you can install them fron your motherboard cd. To install them go to Control panel-> add new hardware-> search for new hardware-> if it shows up then its good else add them from the list. It will then install the drivers from your motherboard cd (the cd you got with your system or from the cd you got with your disk drive).
If this doesn't help then check for the connectors(going into disk drive from power supply and motherboard) by opening your pc.
Please rate the solution.
Thanks
Rylee
Feb 08, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
DVD Player is not playing DVDs
Try to take it for remend, or you can get a dvd copy software to copy dvd to your computer so you can share or watch movie on pc when your dvd player is damaged.
Jul 07, 2008 | Computers & Internet
DVD+RW DRIVE STOPPED WORKING
Try rebooting your computer. I have a similar desktop and sometimes after a period of use the drive seems to power down - if I shut down and start up again it seems to work again.
If this doesn't solve the problem, check the connections inside the computer to make sure the drive has the data cable and power cable connected securely.
If you bought the Inspiron 3 days ago, contact Dell for warranty service and a replacement. If you just bought the drive itself 3 days ago, take it back or return it to the retailer you bought it from for a replacement.
Jun 06, 2008 | Computers & Internet
Sony RDR-VX500 does not load some dvds, disc error.
Try the disks in another DVD player. If they play with no problems in another player, then you have a hardware issue with your Sony. Nowadays, if it is out of warranty, fixing it is not worth it, because it is cheaper to replace, at least in the USA.
Nov 27, 2006 | Sony RDR-VX500 DVD Recorder/VCR
Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo) Burner Logo
368 people viewed this question
Top Teac Computers & Internet Experts
k24674
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
