WET RCA 52" TV
MY BOXER URINATED ON MY TV. AIMED TOWARDS THE SPEAKERS ON THE BOTTOM. THE TV DOES NOT TURN ON. I'M TRYING TO AIR DRY IT WITH MY AIR PURIFIER AIMED AT IT. ANY SOLUTIONS? HELP
    Sergeant:
    Champion:
  • 301 Answers
The damage might already have been done. you can try to take off the speaker grill and the panel behind it to see the CRTs and check to see if there is any liquid damage. there are 3 different Cathode Ray Tubes in your set check the boards they plug into for any liquid and clean as best you can.
after all is said and donand the tv doesnt work i would try and find a tv repair center to look at.
Posted on Feb 20, 2008
Hi guys, I have got a spot on my Sony 40" LCD TV which i got when one of my cat urinated on the TV. its about 4 inch in diameter and is on the bottom right corner of the screen. Now my quest
moisture and electrics dont agree with one another. Could try
isolating from the mains and spraying lightly with car windscreen
de-icer (isopropanol) wipe off any excess and leave in a warm spot for
a few days....Might work if you are lucky
Oct 27, 2014 | Sony "BRAVIA EX 400 Series 40-Inch LCD TV,...
How to clean filters
Unplug the unit. You need to clean the Ionizer plate periodically. Just run it under water and use a clean sponge if you have to. Let the plate dry completely before reinserting it and make sure you put it in the same way it came out. It's marked with arrows on the side that faces the front. The needle itself should be fine without cleaning but if it has some build up on it GENTLY wipe it off with a dry rag. Wipe towards the tip.
As far as the filters go. I haven't had to clean mine. As strange as it seems I get more dust on the front of the machine and the fan than the filters themselves.
Source: I own one of these in black.
Mar 20, 2014 | Microlux Cherry Wood Finish 7-stage UV Ion...
Has been urinated on
remove the battery at once, cleanse it briefly in clear water, shake vigorously to remove excess water and dry in medium hot air... about an hour or 2, re-install the battery and try operating it again.
Mar 27, 2013 | LG Xpression MobiPhone - Red at&t
Id like some instruction on how to use ? curently trying to remove odours from a vehicle ? some instructions on how to use the unit would be a great help
Odors from a vehicle takes 2-14 hours on "high". Depends on the odors. Run the AC & heater fan for 20 minutes also when the car is full of ozone and have the unit aimed up on the floor toward the firewall on high. You should not stay in the car while doing this. Mild new odors can be neutralized in 20 minutes to 2 hours. Bigger and older problems take longer.
May 23, 2011 | Ecoquest Breeze AT Living Air Purifier
The tv wont turn on but the light will turn on and the a second later
open up the bottom left panel in the back of the tv, get a vacuum and vacuum all the dust within and get a hairblower and blow dry panel inside for like ten minutes moving it around , dont let sit in one area for a long time.. after that try turning it on it should work now
Nov 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
Replace a projection bulb on a RCA D52W23?
I have this tv.
pull it out and start undoing the screws towards the bottom half of the tv around the back, get the speaker grille off and then in there is your access cover for your bulbs. theres three of them red blue green. the bulb assemblies and circuit boards are integrated 3 bulbs -three separate assemblies. you will probably have to turn the tv back on when its disassembled to see which bulb went.
jm
Nov 12, 2010 | RCA D52W23 52" HDTV CRT TV
Tv was working fine, then all the sudden the picture warped towards the middle from top to bottom, and everything was like doubled up.
Install the RCA repair kit called the ITC222 and ITC222a convergence option missing repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
Jul 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
My Ionic Breeze air purifier makes an intermittent static noise when operating. What could be the cause and how can I fix it.
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 12, 2009 | Ionic Pro CA500 Air Purifier
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
