Question about Frigidaire Dishwashers
The propeller on the top of my dishwasher came off and i can't figure out how to put it back on. There appears to be a ring inside the opening on the ceiling where the propellor would attach. I have a feeling that a piece is missing. Can you help
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
  • 338 Answers
SOURCE: Need to install a new top spinner on the roof of our dishwasher
the medium sized plastic piece slides into the spinner and you put it upto the manifold. you have to remove the manifold so that you can push the smaller piece of plastic through the top of the manifold into the medium sized piece which would be holding the spinner up.
Posted on Dec 18, 2008
MNTECH
  • 1543 Answers
SOURCE: Center water tower came apart
There have been many versions of the spray tower used over the years. If you have the model HDA3400G which you posted under, you should get a part number WD22X10008 which is the lower spray arm and tower assembly. By looking at the new part, you will see how a couple tabs hold the part on, and can figure out how to remove the old one with a flat blade screwdriver (or two). If you have a different model, please post the exact model number. The model number sticker is generally located on the left side wall of the tub, right by the front.
Posted on Apr 19, 2009
  • 10 Answers
SOURCE: Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Posted on Jun 16, 2009
tbirdfan1
  • 3051 Answers
SOURCE: The top spray arm of
Hello there:
hey sorry i keep getting disconnected i will be back on really soon i need to find out what is going on i hope these things that i have discussed with you is helping you out the parts are not as hard as they look once you getthenew part it will have theinstallation instructions ok
Best regards michael
Posted on Dec 27, 2009
My top propeller fell off how do I put it back on my kenmore 665
It looks like you are missing one more part. There should be a small round cap like dish, that will fit on top of the perpeller to hold it in place, take a look in the dishwasher, posibly near the heat element to see if you can locate this part. The part should have a keyway to help put togeather correctly.
Dec 12, 2012 | Dishwashers
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | GE Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
