Question about SanDisk Sansa e260 MP3 Player
No sound. Tried multiple headphones, volume is up, equalizer is normal, battery is fully charged. What else can I try?
  • 201 Answers
Try doing a reset (or it might be called "factory settings"), which should be under the Settings menu.
Posted on Feb 03, 2010
How do I get sound to my Sennheiser RS120 wireless headphones when it shows as working properly?
Dirty volume control on headphones. Try moving the volume control back and forth several times to clean off the contacts.
Dec 14, 2014 | Sennheiser RS 120 Consumer Headphones
How do I get sound from TV using headphones.
The red & white phono/RCA sockets are a sound input TO the TV. They are not a sound output FROM the TV.
Sep 06, 2014 | Televison & Video
How To Fix Volume Issues on Headphones?
open sound settings in windows system settings ?
Jun 13, 2014 | Gateway Computers & Internet
Low volume nextbook premium
there a few. free apps for this using play store the problem is the built in speakers may not do it so it sounds crackly,one fix I saw was using the equalizer and turning up the bass.I have not tried this yet,they recommend headphones hope this helps
Mar 07, 2014 | Nextbook Premium 8 Se Android
No sound on left ear
I will assume you have tried tuning them via the control mounted on the headphones and still get nothing from the left ear.
First try a different channel setting on the base and retune the headphones.. if this doesn't fix it..
Check all your connections.. at the headphone base as well as the source.
Also I suggest trying them on a different source.
Since you did not mention what the source is.. I will make a few additional suggestions.
If plugged into an amplifier.. try repeated switching between output sources.. If the amp is playing fine through both speakers.. pick up an inexpensive adapter that will allow you to plug the red and white rca jacks into a headphone jack, then try HP output. (some RS 120 units shipped with this adapter)
If the source is the television itself check the connections on the back.. and check your balance settings on the sets main menu.
Depending on how old the headphones are along with frequency of use you may need new batteries.
Make sure the batteries are fully charged.. remove them and test the voltage.. they can do this for you at Radio Shack if you don't own a volt ohm meter or some other testing device.
Replacement batteries are not that expensive.. just make sure you replace them with the exact type (AAA - NiMH) and allow plenty of time for them to charge before use (overnight)
This last bit of advice I suggest caution.
You can put a fresh set of AAA standard batteries in the headphones and test them.. DO NOT PUT THE HEADPHONES ON THE CHARGING CRADLE with these batteries or you MAY DAMAGE THE HEADPHONES.
In fact I suggest you place a piece of tape or something on the cradle before you do this to remind you.. once you finish testing the headphones with standard non rechargeable batteries .. again trying different settings and tunings the set.. If they work .. you probably need a new set of rechargeable batteries..
This is a quick and dirty way of testing/comparing.. but REMOVE the standard batteries immediately after this test. Placing the headphones on the charging cradle with standard batteries in place could cause them to rupture and leak into the headphones.. so again.. be careful if you decide to test them in this fashion.
Feb 08, 2011 | Sennheiser RS 120 Consumer Headphones
I have HDR65/RS65 Sennheiser wireless headphones. I disconnected them to move stuff around, then re-connected them. Now all I get is a 2 second cycle consisting of: 1 second of static that builds in...
Try connecting them to an MP3 player or connect wired headphones to the same source to make sure the sound source is working correctly. If that works, verify the voltage on the batteries is 2.4 volts after charging. Mine stopped charging fully and the headphones wouldn't work at all, but when I connected a couple of AAA batteries to it in series, it worked great.
Nov 15, 2010 | Sennheiser RS 65 Consumer Headphones
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
Left ear of headphones volume low
Out of the box or before using it, you have to charge the headset for about 4hrs or until no light on the headset (red if it's charging). Then try using it again play around with the volume. If you encounter the same thing then you have to replace it at the store.
May 01, 2009 | IOGear (GBE201W7) Wireless Headset
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Jan 02, 2008 | Sennheiser RS 140 Consumer Headphones
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
