Question about Microwave Ovens
MAYTAG MAH8700 FRONY LOAD , BAD VIBRATION ON SPIN ,
  • baber74 Feb 03, 2010
    maytag front lod mah8700 bad vibration on spin , belt ok pump ok bearings ok , level is ok on hard servce ok
    maytag mah8700 vibration in spin , pump ok belt ok drum spins free the shocks look all good no springs broken , level and on solid ground
  • Microwave Ovens Master
  • 43,501 Answers
These front load washers have a problem with the shocks breaking that hold the tub steady. Check out this tip for more on the problem and a secong tip on how to get parts.
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Posted on Feb 03, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue seems to be the pump going bad, you can check it as the pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any foreign objects. The pump is usually at the back right side (looking at the washer from the front).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • 3,230 Answers
Well first of all check to see if the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, if it's frozen or stiff then replace it. If the pump belt is broken or looks quite worn, replace it, but be sure to check the pump pulley before you change the belt. Please post comments for more help or information......
Good Luck!!
Thanks
My maytag microwave starts making a load noise after a minute or so, and occasionally smokes
Open microvave compartment and you can physically see the burnt transformer or capacitor or diode.make sure to discharge capacitor before you start your work
please rate my work
Nov 13, 2011 | Maytag Microwave Ovens
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
My modle # mmv4205aab lost all power, no display, no nothing. thank you
Hello- Unplug, open door, and remove screw holding display panel. Be careful, some wires may need to be unplugged. 20a fuse should be visible. If this fuse is bad- replace and address any power supply issues, such as age of wiring or circuit load-(other stuff plugged in) Hope this helps-ED
Mar 01, 2010 | Maytag Microwave Ovens
Hotpoint microwave is loud.
your transformer windings are loose and the 60 cycle frequenct is setting up a mechanical vibration, you can try and look for anything loose inside the unit, but if the transformer windings get loose theres really no fix but to live with it
Oct 06, 2009 | Maytag MMV4205 Microwave Oven
This microwave GE JES834 800 watts, turns on all by itself , and continmues to turn on
Hi.
Put a cup of water in the unit (if you haven't already). This will tell you if it's actually 'cooknig' or not....... Probably not..... A bad door switch can actually turn on/off lights and fans just from building vibration...... If it does heat the water, the magnetron has most likely been damaged from running empty (no load) and it's usually more cost effective to replace the unit.
Sep 11, 2009 | GE JES834 800 Watts Microwave Oven
When on spin cycle, Maytag MAV5057AWW vibrates excessively more so than just an unbalanced load. When I open the lid the whole tub and agitator is moving around alot forward and back as well as side to...
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 16, 2009 | Maytag MMV4205 Microwave Oven
Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 27, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
