Question about Sony XPLOD CDX-GT200 CD Player
Any time I press a button (even changing the station) it makes a loud sound-- how do I turn it off?
  • 518 Answers
Do you have a manual for this unit? if not i can get one for you, just email me on butcher960@btinternet.com Also to turn the unit off press the off button in the top left hand corner, or press and hold this button.
Posted on Feb 08, 2010
Speakers bose docking station make a noise
Have two Bose docking stations and the oldest (white) one have some problems now. When I put in one of my iPods in the docking, the speakers make some weird, creaky noises. Kind of a sound, when I'm looking for a channel on the radio. When I wiggle a little bit the connector from the docking station, it will play some music for a short time. Still it is not the same quality sound, it used to be. Also, some times the sound is too loud and when I touch ONE time the volume minus (-) button, you can hardly hear the music, it is too soft. Hope somebody can solve this problem.
Sep 10, 2012 | Bose SoundDock digital music system...
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
I have a Midland WR-100. The stations don't work, it just rings. Can I fix this?
Good morning, afternoon, evening or night; whatever time you're reading this. Your complaint is that the stations on your radio do not work and it just rings for no apparent reason? The possible cause of this could be your alert setting. Your alert setting may be set on TONE. When this setting is activated, a ringing sound will be played on your radio for 5 minutes or until any button other than the Weather/Snooze button, on your radio is pressed. If this is the cause to your problem, you need to change your alert type setting. Here are the steps to doing this task...
  1. Press the MENU button.
  2. Use the directional up button until "ALT TYPE" is showing on your screen.
  3. Press SELECT
  4. Using the directional up or down buttons, choose DISPLAY or VOICE.
  5. When this is done, press SELECT.
  6. Press the directional up button until "ALT TEST" is shown on the screen.
  7. Test your alert type to find out if you'd prefer this setting.
  8. If this setting is preferred,press SELECT and MENU to exit. If you prefer to choose another setting, press MENU, then the directional down button until "ALT TYPE" is showing on your screen. Repeat steps 3 through 8.
I hope this solves your problem. Reply back if it doesn't. Thank you for choosing FixYa as your one-stop solution spot for your problem. Make sure to read our Tips & How-to page for this product. Have a good morning, afternoon, evening or night; whatever time you're reading this solution.
Apr 19, 2011 | Midland WR-100 Weather/RDS Radio
How to change the time on the clock
Without Radio Data Systems (RDS): To set the hour, press the clock button. The clock symbol will appear on the display and the hour number will flash. Then turn the ADJ knob to increase or todecrease. To set the minutes, press the clock button again. The minute numbers will flash. Then turn the ADJ knob to increase or to decrease. The time can be set with the ignition on or off.
With RDS: Same as without RDS unless you want to Sync. with a radio station. To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED appears on the display. If the time is not available from the station, NO UPDATE will appear on the display. RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it may take a few minutes for the time to update
Nov 29, 2010 | 2005 Chevrolet Cobalt
I cannot adjust the stations, switch to CD or Radio mode or anything as it's stuck on one XM station. The presets won't even change the station. I noticed the disp/title button seems to be sort of stuck...
Yes, Disp/Title stuck button could be cause of no other button function because one button can be operated at one time in these units and if any button stuck for some reason, other buttons would be inoperative.
Take off front panel by pressing eject button at lower left side and try to release Disp/Title button with finger nail, if that does not help then remove screws at back of front panel, take off back cover then take out circuit board carefully and press gently, little bit Disp/Title knob from inside front panel to send it back in its original position then put circuit board and put back cover and tight screws.
Check Disp/ Title button gives little click sound while pressing as other buttons give that sound. Put front panel in unit and check.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Nov 13, 2010 | Alpine CDA-9820XM CD Player
How do I change the time on the radio in my '08 pontiac g6
To set the hour, press the CLOCK button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the CLOCK button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Nov 07, 2010 | 2008 Pontiac G6 Sedan
My computer was running very loudly, for a couple of days, than one morning after working properly for a few hours the power went out and it won't even turn on.
does it make a sound when you press the on button? cause if not you might have a problem with your power supply.
if it does make a sound it might be motherboard problem.
if it makes a beep(ing) sound(s) it could be fixed most of the time for under $100 no promises:)
just in case try to unplug the power from the computer >> hold the power button for about 20sec >> plug the power back in and turn the computer on see if that works.
post back with a bit more info such as what you hear when you press the on button (any sound at all even its a short one).
-mike
Sep 24, 2010 | Computers & Internet
Manual stolen when car was vandalized, need to know how to set clock and radio stations in 1994 Ford Tempo please
setting stations on Fords are easy,put it on the station you want to program and push the channel button in and hold for about 2 seconds then it should flash,now the channel is set..now for the clock,with the key on and radio turned off,press the clock button,then press the seek or scan forward or reverse to adjust the time,then hit the clock button again to make sure it sets.
Oct 22, 2009 | 1994 Ford Tempo
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Battery Problems with 2001 Dodge Stratus
sounds like your alternator is bad have it tested to see
Nov 22, 2008 | 2001 Dodge Stratus
Sony XPLOD CDX-GT200 CD Player Logo
63 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
